Question about Hannspree HANNS pad SN10T1
How to activate camera on hannspree - Hannspree HANNS pad SN10T1
Why wont my hannspree 10.1" tablet connect to onboard cameras?
to contact a camera, you need a correct working camera app. If the app you try to use does not work, reinstall the app, or choose another app from the App Store.
Jul 22, 2014 | Hannspree HannsPad SN10T1
How to fix camera can not connect on hannspree tablet
Hard reset your tablet , if your tablet is updated the camera stops functioning. Hold power and Up or Down volume button to hard reset.
Jun 28, 2014 | Hannspree SN10T1 101 Tablet
I have a hannspree SN1AT71WEE301 i cannot connect to the camera is there an easy fix.
Assuming the built in cameras are the issue,
\are you using the provided software ?
You can try to update the ROM and / or drivers for those devices.
sometimes an update may not install properly and re-updating the ROM and / or specific device drivers would solve the issue
Attached is a link for the English device manual:
http://www.hannspree.eu/uploads/Downloads/TabletPC/UM/SN1AT71/SN1AT71_User-s_Manual_EN.pdf
If you are having difficulties with the device recognizing an attached camera device, you may need to go to camera device manufacturer website and download the appropriate drivers to match your tablet device operating system and connection type.
Ex: USB driver for camera connecting using a usb port connection. Also ... confirm proper cable is being used.
Ex: Some connections require 5 contact point cables, others only 4 contacts - this will be determined by your devices.
I hope this was helpful.
May 08, 2014 | Hannspree SN10T1 101 Tablet
Cannot connect camera error
Mine has stopped working as well. I did as restore, deleting everything. Don't bother. It didn't fix it. I am calling Hannspree today and will post here if there is a solution,
Apr 04, 2014 | Hannspree SN10T1 101 Tablet
Static with cpu activity
There is clearly a fault with the unit.
Return it as Dead On Arrival.
Dec 11, 2013 | Hannspree 10.1-INCH QUAD CORE TABLET PC T7...
Hannspree Hannspad user manual
My 10.1 hannspreed tablet will not download free games after I reset it to factory,what did I miss ?
Feb 14, 2013 | Hannspree HANNSpad Tablet User Manual
Hannspree HANNS pad SN10T1 Logo
15 people viewed this question
Top Hannspree Tablets & eReaders Experts
yobo007
yobo007
David Payne
David Payne
William Alequin
Are you a Hannspree Tablet and eReader Expert? Answer questions, earn points and help others
