Question about Samsung Washing Machines
What does 5ud - Samsung Washing Machines
Machine is not spinning to get excess water out. code 5ud showing on screen
5UD is actually 'SUDS', it means the pump has noticed there is too much soap and is having difficulty pumping out. Are you using HE detergent?
If you leave the machine for an hour and then set it to Rinse and Spin, it should clear.
Jan 24, 2017 | Washing Machines
What does 5ud mean 10 minutes from finishing 5 Ud displayed can't open door?
The SUD (not 5UD) code is displayed when excess foam is detected (possibly because excessive detergent is being used). If your machine does not cure itself, you may have to run an "Eco drum clean" cycle (if your machine has it) or a 90 degree cotton cycle with no detergent and no load.
Aug 29, 2016 | Samsung Washing Machines
What does 5ud mean on a elite he3
I think the 5UD is SUD. It means excessive sudsing has been detected, and a suds routine has been started to reduce excessive suds. This routine will add time to the original cycle. I have had this on my display a couple of times when I guess I put too much HE soap in the machine.
Jan 15, 2012 | Kenmore Washing Machines
Washer code 5ud
Hello & Welcome to FixYa
Sud error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Dec 02, 2011 | Kenmore Elite 45986 Front Load Washer
What does '5ud' or Sud displayed on the light console mean?
It is meant to be SUD rather than 5UD and it stands for 'suds'- too much sudding. Machines normally go into a mode to flush the suds out at that point. As a suggestion it could be you are using too many tablets/too much soap powder.
John C
Feb 16, 2011 | Whirlpool Washing Machines
The washer screen says 5ud. wat does that mean?
"SUD" means just that - suds. It may mean too much detergent, or drain pump clogged, or water level switch is faulty. Check drain line and drain pump first.
Vlad
First Choice Appliance
Feb 05, 2011 | Dryers
We have a Samsung WF8802 RPZ washing machine with a 5ud fault code. What is the problem?
We have a Samsung WF8604NGW front loading dimond 6kg washing machine. We had the 5ud error message. It turned out the filter was clogged with fluff from a new set of bathroom mats my wife washed. To fix: Put the machine on to drain (if poss) - should be 1 minute on our machine however as the machine was so clogged it took around 15 to finish. Also use the draning tube located next to the filter (on our machine) to get rid of as much water as poss. Now remove filter and clear (warning some water will remain in the system) Before spinning any laundry run the rinse cycle (with an empty drum) a couple of times and clear the filter each time. If the filter is still clogged the laundry will spin heavy as the water will still be in the drum leaving you with no very dry laundry and a horrible noise during the spin. Regards Rik.
Nov 14, 2010 | Samsung Washing Machines
Have error code 5Ud can you explain what this is as manual does not have code listed?
It is actually "SUd" probably didn't use enough softner/too much detergent. i clear it by running "quick wash" with no addidtives, gives me two rinse cycles in 35 minutes, done.
Jul 09, 2010 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
