Question about Mayline Group Mira Series 8 Racetrack Conference Table MCTDB4896 by Mayline
How to remove the cover from the mira 8 shower
I have a Mira sport shower 'it was leaking water so I had to have it removed from bathroom wall,would it be possible led to have it repaired.
Absolutely... Scott Fullerton,
It appears to be a UK item...
My best recommendation would be to contact Kohler-Mira
by using the attached numbers and asking them for a local shower service RECOMMENDATION...
UK
Telephone: 0844 571 5000
www.mirashowers.co.uk E-mail: technical@mirashowers.com
Fax: 01242 282595
By Post: Mira Customer Services Dept, Cromwell Road,
Cheltenham, Gloucestershire, GL52 5EP
Eire
Telephone: 01 459 1344
E-mail: sales@modernplant.ie
Fax: Dublin 01 459 2329
By Post: Modern Plant Ltd (Dublin),
Otter House, Naas Road, Clondalkin, Dublin 22
© Kohler Mira Limited, February 2011
32
(www.mirashowers.co.uk)
OWNERS MANUAL (contact information)
Mira Sport Thermostatic 9 0 Installation User Manual Page 32
Hope this helps
Carnac the Magnificent Carnac the Magnificent
Nov 23, 2017 | Home
My mira elite 2 shower is leaking,The flow and tempt is ok. but the leak has got worse and it is cold water the leak is not from the hose that is connected to the shower head. It only leak when its on
Please use plumbers white tape wrapped in a clockwise diection. Tighten and let us know Geraldine. Thank you and send us a picture if you can. Best of luck leave feedback
Jul 13, 2016 | Home
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
Mira shower manuals
If you have water with head removed, Remove and soak shower head overnight in vinegar to remove hard water deposits.
Jun 09, 2014 | Home
My mira Vigour is leaking from inside the casing. Is it worth while fixing it. Can parts be got.
All Mira vigour parts are available. Try dublinshowerrepair.com
0872885385. They give free advice and may be able to tell you if it's worth fixing. Best thing to do is take cover off & take a photo & send it to them.
Aug 30, 2013 | Home
I have a Mira Vie electric shower, the pull cord no longer lights up, and therefore my shower won't run. I've checked the fuse box and nothing is labelled, it's an old style fuse box. Ther
Buy a current tester( under a tender) and test if supply is going to pull cord (remove the 2screws on cover of pull cord. )Ifyou have power then it's you pull cord that needs replaced if not its mains fuse
Sep 26, 2012 | Home
After about a year after installation our mira thermo shower has started to run cold after about half a minute or so. The same thing happenned to a previous cheaper type of shower which is why we replaced...
Your shower valve has an temp equalizer valve in it, you will have to take it apart, clean all the calcium or debris from it. flush out the hot and cold lines with valve dismantled , cover drain to make sure you don't lose any parts. reassemble with Vaseline. good luck.
Mar 14, 2011 | Home
Every time we use the shower there is a very pugnent smell [fishy] all drains been checked, all pluming been checked, all water is fine. shower is 11 years old could this be the problem. the shower we have...
Also check the following things:
The control unit, hose and shower head - depending on the type, some heads will hold water. Remove them and check to see if they are exhibiting signs of mold or possible failure. At 11 years old, the element could be on its way out. If your Mira unit has an auxiliary pump, it should be checked as well. If it's the shower head, you can try to soak it in white vinegar to remove the smell, or simply replace it. If you have well water, you should consider flushing the system to be sure water isn't being trapped somewhere. Also, if the iron content of the water is high, or if your water softener isn't operating properly, that could be an issue as well. The Mira control unit may need to be de-scaled or otherwise checked.
Check the shower stall walls (with no tub) at the bottom where they meet the basin, unless the shower enclosure is all one piece. There could be mold behind the intersection of the walls and base.
Look for any trace of mold growth around any other enclosure components.
If the shower is in a tub, remove the overflow cover on the tub and see if there is any trace of mildew or mold in that area. Follow your nose.
Finally, check for any excessive build up of soap scum, although this is less likely because you'd notice it more readily.
Things like this can be tough to diagnose, so just take things slow and one at a time.
Mar 08, 2010 | Home
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
How do i adjust a mira shower to run hotter
There is a anti scald thermistor inside the center section of your shower knob's. You need to remove the cover and take out the center section. Rotate the know counter clock wise one or two notches. Replace and test the water temp. I just bought one for my house kinda nice I guess they made these in case someone flushed the toilet while someone was showering. ken
Dec 30, 2008 | Heating & Cooling
Mayline Group Mira Series 8 Racetrack Conference Table MCTDB4896 by Mayline Logo
422 people viewed this question
Top Mayline Group Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Mayline Group Furniture Expert? Answer questions, earn points and help others
