Question about OKI Office Equipment & Supplies
Oki c5300 tray 1 empty but I have paper in tray 1
    Problem Solver:
  • 18 Answers
There is a black sensor flag that will hang down from printer when tray is removed. verifiy it moves freely
Posted on Dec 17, 2014
SOURCE: Okidata 5100C error code 490:MP tray empty
remove toner from your printer see any paper or wheels are jammed or loose...
Posted on May 28, 2008
SOURCE: Stopping Auto Tray Selection
If you use different print materials of the same size in the trays, each tray with a different print material should have a unique paper type setting to prevent the printer from linking the trays together and mistakenly printing on the wrong paper.
From the printer's operator panel, choose the paper menu, then paper type, then select the source (ie, tray) that you want to change.
For example, if you have plain paper in tray 1 and preprinted paper in tray 2 and both are set up where size = A4 and type = Plain paper then when Tray 1 runs out it will automatically feed from Tray 2. To prevent this from happening you should change Tray 2 type = Letterhead. In this way, the printer knows that the two media types aren't identical and won't pull from that tray unless you specifically tell it to.
Posted on Mar 10, 2009
  • 111 Answers
SOURCE: I NEED THE SERVICE MANUAL FOR OKI C5300
Try this
http://www.okic5300.co.uk/library/documents/c5300/5300uGB3.pdf
Posted on Aug 20, 2009
  • 21 Answers
SOURCE: oki b6200 paper jam
restart the printer or reinstall driver again.
Posted on Oct 08, 2009
shadiabed
  • 72 Answers
SOURCE: Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Posted on Jan 08, 2010
Error oki b6100 e2
This error often comes when there an paper jam or paper tray 1 or paper tray 2 or 3 is empty,make sure that you have enough paper in the trays and secondly make sure that you have there is no paper jam in paper roller, even an tiny particle of paper can cause this error.
Please open all the access of your printer pull out all the paper trays and clean it properly with air blower, this can fix this error.
Sep 02, 2011 | OKI C5400 Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
How to do borderless printing with an oki c5300
You cannot do borderless printing with a toner/fuser based unit.
The printer needs a paper grip area and cannot print to the edge due to the fuser.
Sep 30, 2009 | OKI C5300n Led Printer
OKI Laser Printer C5300 printing on paper with black flecks
IF you are using after market black toner then we found your problem. Putting a real toner on now wont help cause dodgy toner is now in the drum, you need to replace Black drum and use real toner. If you are using gen OKI toner, then just replace the Black (K) drum.
Clean led head and these printers dont need a teco, they are designed for wearing parts to replaced by operator ie Transfer belt, fuser, drums and toners.
Nov 20, 2008 | OKI C5100n Laser Printer
Oki printer problem
Possibly a defective paper sensor (small lever in the tray contacts
paper) Try removing, and inserting paper a few times if this clears it
then it was sticking.If that dosen't work then you will have to
disassemble it and inspect the area of the tray switch to determine
it it needs replacement
Nov 14, 2007 | OKI B4350 Laser Printer
Oki C5300 toner "leaking" on to surface
1 - take out all consumables
2 - use canned air to clean interior (do it outdoors)
3 - spray toner cartridges to remove stray toner (keep them connected to the drums, do not separate)
4 - make sure toner carts are properly installed and locked down
Oct 25, 2007 | OKI C5300n Led Printer
My oki printer
Make sure you specify the correct tray from your application. Tray 1 might be refering to tha manual or bypass tray.
Sep 13, 2007 | OKI C9500dxn Led Printer
112 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
