Question about OKI Office Equipment & Supplies
Oki c5300 error message 491 tray 1 empty but I have paper in tray 1
SOURCE: Okidata 5100C error code 490:MP tray empty
remove toner from your printer see any paper or wheels are jammed or loose...
Posted on May 28, 2008
SOURCE: Stopping Auto Tray Selection
If you use different print materials of the same size in the trays, each tray with a different print material should have a unique paper type setting to prevent the printer from linking the trays together and mistakenly printing on the wrong paper.
From the printer's operator panel, choose the paper menu, then paper type, then select the source (ie, tray) that you want to change.
For example, if you have plain paper in tray 1 and preprinted paper in tray 2 and both are set up where size = A4 and type = Plain paper then when Tray 1 runs out it will automatically feed from Tray 2. To prevent this from happening you should change Tray 2 type = Letterhead. In this way, the printer knows that the two media types aren't identical and won't pull from that tray unless you specifically tell it to.
Posted on Mar 10, 2009
  • 1126 Answers
SOURCE: MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Posted on Aug 18, 2009
  • 21 Answers
SOURCE: oki b6200 paper jam
restart the printer or reinstall driver again.
Posted on Oct 08, 2009
SOURCE: I am getting error message ' Load Tray 1, 024-910,
Make sure that after you add paper, that you tell the printer the right size paper. Chances are you accidently changed the paper size and the printer is letting you know that the "wrong" paper is in the tray. If you are using standard printer paper, be sure to change the paper settings back to "Letter"
Posted on Jan 12, 2011
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
Oki c5300 tray 1 empty but I have paper in tray 1
there is a black sensor flag that will hang down from printer when tray is removed. verifiy it moves freely
May 06, 2014 | OKI Office Equipment & Supplies
How to fix error 491: Tray Empty on Oki c5400
printer oki b411dn put out of the balcony, unsatisfied by his work, too many error codes, to lost time, to failed
Feb 27, 2012 | OKI C5400 Laser Printer
Error oki b6100 e2
This error often comes when there an paper jam or paper tray 1 or paper tray 2 or 3 is empty,make sure that you have enough paper in the trays and secondly make sure that you have there is no paper jam in paper roller, even an tiny particle of paper can cause this error.
Please open all the access of your printer pull out all the paper trays and clean it properly with air blower, this can fix this error.
Sep 02, 2011 | OKI C5400 Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
How to do borderless printing with an oki c5300
You cannot do borderless printing with a toner/fuser based unit.
The printer needs a paper grip area and cannot print to the edge due to the fuser.
Sep 30, 2009 | OKI C5300n Led Printer
Oki printer problem
Possibly a defective paper sensor (small lever in the tray contacts
paper) Try removing, and inserting paper a few times if this clears it
then it was sticking.If that dosen't work then you will have to
disassemble it and inspect the area of the tray switch to determine
it it needs replacement
Nov 14, 2007 | OKI B4350 Laser Printer
Oki C5300 toner "leaking" on to surface
1 - take out all consumables
2 - use canned air to clean interior (do it outdoors)
3 - spray toner cartridges to remove stray toner (keep them connected to the drums, do not separate)
4 - make sure toner carts are properly installed and locked down
Oct 25, 2007 | OKI C5300n Led Printer
189 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
