Remington typewriter the space bar is stuck in the down position how do I free it
  • 3594 Answers
SOURCE: IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Posted on Jul 02, 2009
  • 20 Answers
SOURCE: There's an ancient Remington 10 typewriter in my
Usually very little value to old typewriters. Too many made. Either put on e-bay and see if you can get $20-25 or put in a garage sale. If you're in no hurry, keep it in the attic for another 20 years and see if the market improves! :)
Posted on Oct 25, 2009
unaasp192
  • 29 Answers
SOURCE: Panasonic R320 Typewriter ... Carriage is stuck
check underneath if there is something stuck under the carriage.
pass your hand on the ironpipe of the carriage,if it is sticky. take a towel put some oil 3inone on it and sweep the bar.
if the dont help, get a technician to check the motor.
unaasp192
Posted on Apr 12, 2010
  • 61 Answers
SOURCE: Typewriter will not space
It sounds as if the spring in the drum under the carriage has broken. Major problem.
Posted on May 01, 2010
JUSTOLDJIM
  • 478 Answers
SOURCE: old remington typewriter the space
Most likely caused by rust search it out lube it a little then work the key up and down to free it up.
Posted on Dec 13, 2010
I have a Smith-Corona Super Correct electric typewriter and the spacebar is stuck on the downward position.
Some of these have a leaf spring that either twist to the side or breaks. Usually there is a spring that pulls that space bar back up.
Sep 24, 2017 | Smith Corona Office Equipment & Supplies
Remington
it could be at the right margin try pressing margin release key
Sep 04, 2014 | Office Equipment & Supplies
My lexmark typewriter space bar will not work and the phrase light is stuck on
The phrase light is also the single space. If only the space bar doesn't workyou may have a bad keyboard or something under the space bar that is in the way.
DickyO
Aug 23, 2011 | Lexmark Wheelwriter 1500 Typewriter
I get a dbl space between words every time I push my space bar. How do I change that?
DEPENDING ON THE MODEL, THE SPACE BAR COULD BE STUCK DOWN SLIGHTLY SO WHEN DEPRESSED IT GOES INTO REPEAT. CHECK TO SEE IF STAPLES OR PAPER CLIPS ARE DOWN IN THE KEYBOARD, JUST MAKE SURE THEY DON'T GO THROUGH TO THE LOGIC BOARD WHICH IS MOUNTED UNDER THE KEYBOARD ON MOST SWINTEC
Aug 18, 2010 | Swintec Office Equipment & Supplies
Silver-reed 500 stuck spacebar
Gently pry a couple of keys above the space bar and look for for forgien objects under the space bar.
DickyO
Jan 21, 2010 | Office Equipment & Supplies
There's an ancient Remington 10 typewriter in my attic - levers and knobs all over the place, and even a space bar made of wood! Is it any use to anyone?
Oct 14, 2009 | Office Equipment & Supplies
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
Margins
Most electronic typewriters work the same way to change margin settings. You use the space bar to move to the desired location then press the right margin key. You should hear a beep. If you need to set it farther to the right of the current position, then use the space bar to move the carrier to the current position, once it stops moving then press margin release then space to the new position then press right margin key.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2008 | Brother EM-530 Typewriter
k24674
jasbo
jasbo
