Question about Topcon Electronics - Others
Rapid clicking noise - Topcon Electronics - Others
My 2007 Altima makes a rapid clicking noise when the car is in gear and the brakes are keeping the car at a stand still. It goes away when placed in park or neutral. The noise seems to be coming from the...
I would look more towards the belt tensioner. Look at it when idling, Then when some one puts it in gear. If it is jumping, which they do. See if it is coinciding with the clicking.
Feb 24, 2016 | Cars & Trucks
Renault Grand Scenic - Dashboard flashing red light, clicking noise throughout car.
Hey,
You can try another battery if you have one, or take the battery to be tested somewhere to see if its at fault
Thanks,
Ekse
Sep 04, 2008 | 2005 Renault Sportwagon
My vehicle makes noises when i accelerate
98% sure you have an axle problem. Might be wheel bearings depending on the sound. Bad axles will make a loud clicking noise, (click click click in rapid succession, espically while turning or under accleration) while wheel bearings will make a growling sounds.
Dec 09, 2013 | 1995 Nissan Quest
There is a rapid clicking noise from my peugeot 307 when I turn the key. What could it be.
In my opinion its relay that is located near fuse box situated insied glove box (open glove compartment and look far right side of it and you can see a plastic housing. Just turn plastic screw lock 90 degree and you can see the fuse box. Check which relay is making this rapid clicking.
Jul 28, 2013 | Cars & Trucks
Started truck and just got a rapid clicking noise
That indicates a poor connection, a bad battery cable, or bad ground. Check for all three. Check engine ground, engine to frame ground, and battery ground. Clean and tighten battery connections, starter connections. Check your cables.
Mar 25, 2013 | 2004 Dodge Ram 1500
Car won't start. Makes a rapid clicking noise when ignition is in start position
The rapid clicking noise is caused by low battery voltage, you eiother have rub the battery down or the battery is defective or the battery cables are loose or corroded
Dec 20, 2010 | 2004 Pontiac Grand Prix
Rapid clicking noise coming from under the dashboard.
If you have a tape cassette player in the dash, this can cause a sound like what you are describing. Even though a tape is not in it,,, it can still freak out and cause this sound. Had this happen on several of my old vehicles. Let us know if this helps. Leave feedback for others to see. Thanks.
Nov 08, 2009 | 1995 Nissan Altima
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Electronics - Others Logo
43 people viewed this question
Top Topcon Electronics - Others Experts
Are you a Topcon Electronics - Other Expert? Answer questions, earn points and help others
