Question about Casablanca Fan 3245T Ceiling
Casablance fan repair
Fan blades attach to a hard rubber spoked flange that is connected to the motor shaft. All the flange spokes have sheared somehow. Old Ventura model. Can I find spoked fan parts? Should I just replace the whole thing.
  • 709 Answers
Hi Billsboy,
You can get replacements I believe. Call 979-553-3260 and talk to Gulffans Ceiling Fan parts. I know they have lots of Casablanca parts.
Posted on Nov 03, 2007
I got a new (out of the box) LG window unit about a month ago and about a week later started making this awful noise that would wake me out of a dead sleep. It happens about every 10 minutes and I'm at...
compressor fan blade stripped out,,and the motors shaft is slipping..LG uses plastic fans ,,Ive replaced 4 on mine in the past 5 years,,,,part around $30
Aug 26, 2011 | LG Electronic Window Air Conditioner
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
When I flip the switch it wants to come on and it buzzes but the blades don't go around
The next time you turn it on, try pushing the blades a bit to see if that will get it going. If it does not start running the problem may be as simple as lubricating the shaft the fan blades are hooked to, debris in the motor windings or possibly a wiring issue. Also, the fan blades all hook to a hard rubber ring that holds them to the fan. Be sure none of the blades have broken off this rubber ring.
Please get back to me if these solutions do not prove helpful. Paul
Sep 18, 2010 | Hunter (25417) Ceiling Fan
It wants to start up but it won't
Paul
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
There is a humming noise coming from fan no matter what speed it is on. I have run the fan for hours and still humming
The key to a quiet fan is to isolate the motor vibration from all other parts. This occurs, in the majority of fans, in three places: between the motor and the blade brackets, between the blade brackets and the blades, and between the downrod/motor flange and the mounting bracket. Some fans also have vibration-isolating material between the mounting bracket and the ceiling. If your fan makes a noticable humming noise, inspect it for the above mentioned types of vibration-isolating material. With the exception of the rubber flywheel, if your fan is lacking any of the above, they are easy to add and should solve the majority of humming problems. You can always add additional material as rubber washers and spacers are readily available.
Jun 09, 2010 | Hampton Bay 52 In.Carriage House II in...
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
I have a HotPoint side by side refrigerator. Model # CSX22GAS, my ice is melting and in the freezer section there is a loud noise. as if the motor is running hard.
Below is a link courtesy of www.repairclinic.com, that shows the evaporator fan blade. This may have come loose from the fan motor shaft and may be striking the fan shroud or rattling on the motor shaft
A loose fan blade cause elevated temps. If the fan blade is loose, replace it, not repair it, to avoid further problems.
1. Evaporator Fan Blade:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-CSX22GAS-%3d%3di2611&PartID=2611
2. Evaporator Fan Location: Mouse over parts for illustration.
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Aug 13, 2009 | Hotpoint Refrigerators
Ceiling fan
There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
Apr 27, 2006 | Hunter Sontera 52" Ceiling Fan with...
Casablanca Fan 3245T Ceiling Logo
244 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
