Question about Hammering
Skil 2868 Where can I upgrade the tread size of the end that holds the liquid ?
How do I remove a stripped screw?
drill it out with a drill bit slightly smaller than the size of the screw.
Oct 06, 2015 | Skil Saws
How do I install paper to Skil Dual Action Sander model # 7372?
Sander has 2 slotted rotating rollers one on each end the paper gets fed in as you rotate roller, which will grasp paper and hold, feed/wind roller with slotted screwdriver till paper secure. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Skil nbsp7372 TYPE 1 nbspDUAL ACTION SANDER 348542
Jul 28, 2014 | Skil Tools & Hardware - Others
I have the Roger black treadmill and need to know the screw sizes that hold on the tread mill on the roller at top end of machine as mine come loose when running and then the belt slides of the motor..,,,,...
you need to Read the owner manual, in the section for assembly or dissasembly they appear the screw sizes needed for any section.
or download free from www.fitness.manualsonline.com +
www,retrevo.com
God bless you
Jul 17, 2013 | Exercise & Fitness
Skil hevy duty drillhammer
It is called a chuck and comes with a key. Purchase from any hardware store Comes in 1 /4--3/8 and 1/2 sizes ( Drill sizes)
Apr 26, 2013 | Drills
I have a Skil Belt Sander 405. I bought at a sale. How old is this sander? How can I get a belt for this sander?
http://cgi.ebay.com/4-x-21-3-4-sanding-belts-36-grit-qty-10-/310329120043?pt=Sanders_Sandblasters&hash=item48410e952b
this is the type of belt it uses (size rather) 4"x21 3/4" you can find them on ebay.
http://www.skiltools.com/en/ here is the official skil website. they can probably email you an owner's manual if you wish
hope this helps out. this one is vintage from what i understand
thanks,
mike w
Jul 07, 2011 | Skil Tools & Hardware - Others
Sorry, can i have a number of serie for to use adobe InDesign CS5
Adobe InDesign CS5 serial number:
1037-1064-5873-2868-1490-5369
Apr 07, 2011 | Adobe Photoshop Extended CS5 Upgrade ...
Skil saw motor runs but blade won't spin
you have a loose nut.  Let me explain...the nut and washer that holds the blade to the motor has worked loose.  You need to remove the plate around the blade to acess it and on the end of the blade is a large nut.  Tighten it with the power off.  Sometime there is a grove on the motor shaft to hold the motor or sometimes you need to put a screwdriver into the teeth of the blade to hold in place to tighten.
Apr 04, 2009 | Skil 10" Table Saw
SKIL 18V BATTERY PACK
There are three visble screws and one hidden. Use the right size torx driver if you have it, or a small allen wrench works too and undo the screw that is visble on one side of the pack. Snap the false bottom off of the pack and reveal two more screws to remove. One screw is behid a plastic cap over a fourth obvious screw location. Drill the cap and unscre this screw also. Be sure there are no lables holding the two side together. Pressing down on the battery holdin clasp makes the sides easier to separate. Watch for falling parts. That's it!
Nov 28, 2008 | Skil 2887 05 18 Volt 2 Speed 3/8 Inch...
Hammering Logo
91 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
