Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
How do i replace the square breaker
Doesn't work
  • Intermatic Master
  • 5,245 Answers
Application
Use siemens for old ITE breaker box.
Square D will not work:
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment and describe product, and attach photos.
May 26, 2013 | Square D Co. HOM130C Circuit Breaker
What main breaker
Look at label of marking on breaker box.
Square D would have D with a square.
Take one of the individual circuit breakers to local box store and see which brand breaker matches.
Or take circuit breaker to electric supply house and see who sells that main.
Not all mains are available.
And if main was getting hot, it might have damaged the busbar so whole panel needs to be replaced.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Oct 27, 2012 | Electrical Supplies
Check charging system light comes on intermittant, 2006 taurus, any speed and any load, battery good, alternator replaced problem persists before and after
Check to ensure that the belt is tight. Sometimes the tensioner for the serpentine belt sticks and doesn't properly tension the belt. Usually there's a square hole in the tensioner that one can place a breaker bar into to gain leverage to move the tensioner.
Aug 03, 2012 | 2006 Ford Taurus
Not Eaton but Square D. Arc Fault trips with new vacuums Kenmore 21714. Replaced vacuum cleaner, still happens. Suspect design flaw
you say you have a square d panel and you have a eaton breaker this may be the problem square d should always have a square d breaker and eaton with eaton they dont fit wright in the panel they are made for each other ,you should check the panel and breaker to see if all the wires are tight if there is no problem there check the plug in the wall if there all tight ,it may be drawing to many amps and blowiing the breaker,
Sep 13, 2011 | Eaton Electrical Supplies
I want to replace a 45 year old Federal Pacific (Stab Lok) electrical load center. It is a small one (12 spaces) and am looking for info on the proper replacement. It is currently carrying 100 amps. 3 20s,...
I prefer Square D panels. They have been easier to install than others in my experience. When you say you have 2 30s that are joined you mean you have wires piggybacked together on the breaker? or a tandem 30?
Sep 05, 2011 | Square D Co. HOM2040M200C Main Breaker...
I have a square D breaker with shunt trip. The breaker keeps tripping so how do I check the breaker?
A shunt trip breaker operation.
It works just like a normal circuit breaker with one additional function. A shunt-trip breaker also has a built-in magnetic coil that can be energized externally to trip the breaker.
So what is wired to the shunt that is not letting the breaker reset?
Read more: http://wiki.answers.com/Q/How_does_a_shunt_trip_breaker_work#ixzz1EXNCP5r0
Feb 20, 2011 | Square D Qob120 Circuit Breaker With Shunt...
I need a 15A GFI circuit breaker that fits into a Square D Homeline Load Center - it is not available locally - what other manufacturer's 15A GFI circuit breaker fits into a Square D Homeline Load Center?
That number in the heading is not correct. While you might find a breaker that "fits" your panel there is no other brand that is listed to work with your panel The correct number would be
HOM115GFICP If you can't find it locally, there are many locations you can order one from online. I don't know where you are locatged, but an electrical supply house or even homedepot should have one.
Nov 21, 2010 | Square D Circuit Breaker Load Center...
The garbage disposal & overhead sink fixture run to the same Square D Qob120 1pole 15amp 120v Circuit Breaker . After a week of consistentlu tripping, the breaker won't allow itself to reset. ...
I would start by replacing the breaker. If a new one trips then check ground and wiring. If it still trips then there must be a problem with the garbage disposal. let us know
Sep 21, 2010 | Square D Qob120 1pole 20amp 120v Circuit...
I have hot tub control by Square D QO260GFI. The curcuit has tripped to off position and when I try to flip it to on position it just stays in nutral.
Hi!!
The breaker may be defective is not rated for the load been used or one of the devices the breaker is controlling is either defective and is drawing too much current.
try disconnecting the devices ie: pump motor or heather. one at the time, this is to find out if they work ok by themselves, test one by one. If the pump do not want to start up, it may be the start capacitor. If both devices trip the breaker, Replace breaker.
Good Luck!! Don't forget to rate this post!!
Sep 03, 2010 | Square D Circuit Breaker QO260GFI
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
67 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
