Question about HP Photosmart A636 Compact Photo Printer
Will not print all colors
Will not print yellow, have replaced cartriage,ran all test, no error codes
jbreth
  • 69 Answers
SOURCE: HP DeskJet 970Cse won't print yellow
Here is a link to hp's web site. They will troubleshoot your issue. This link is linked to a page talking about HP Inkjet Cartridges and Media - Missing Color, Wrong Color, or Streaks in the Printout. There are several links in this site to go off of and troubleshoot further. Hope this is helpful:) http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&lc=en&cc=us&dlc=en&product=60097&rule=34749&lang=en Jason
Posted on Sep 04, 2007
  • 5 Answers
SOURCE: DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Posted on Feb 11, 2008
futureloginn
  • 734 Answers
SOURCE: HP Photosmart 3200 All-In-One not printing yellow
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Posted on Dec 04, 2008
steveparlin
  • 61 Answers
SOURCE: HP LaserJet 1500... prints color yellow ONLY
Missing or incorrect color
 You have changed the color settings manually. Return the color setting to Automatic. • Windows: On the Color tab of the printer driver, click Automatic. • Mac OS: In the Print dialog box, select the HP ColorSmart or HP Color Quality pop-up menu and then select the Manual option.
 Your print media does not meet the specifications for this printer. For example, you are using coated, glossy, or photo paper. Use a different paper, such as a high-quality paper designed for laser printers. See the user guide for information about print-media specifications.
 You are operating the printer in excessively humid or dry conditions. Verify that the printer environment is within humidity specifications.  A print cartridge might be low on toner. Check the printer control panel, print a Supplies Status page, or view the embedded Web server (HP color LaserJet 2500 series printers only) to see supplies status. (If you are using a non-HP cartridge, none of these sources will provide information about a low or empty print cartridge.) If a cartridge is low on toner, replace the print cartridge.
Clean the sensors and perform a calibration.
The HP Color LaserJet 1500 Series Toolbox is not supported for the Macintosh operating systems. 1 Make sure that the printer is turned on and in the Ready state. 2 Open the Toolbox. 3 On the Troubleshooting tab, click Cleaning Page and click Print. A page with a pattern prints from the printer. 4 At the printer, remove any media from tray 1 (multipurpose tray). 5 Remove the page that printed and load it face-down into tray 1 6 At the computer, click Clean.
Note For even better results, repeat this procedure several times.
The printer automatically performs a calibration when the imaging drum or a print cartridge is changed, and at set intervals that are determined by the total number of pages the printer has printed. For the HP Color LaserJet 2500 series printers, you can change the interval at which the printer performs automatic calibrations by using the embedded Web server.
To calibrate the printer manually Turn the printer off, wait one minute, and then turn the printer on again.
To calibrate the printer from the Toolbox The following procedure must be performed from the HP Color LaserJet 1500 Series Toolbox or the HP Color LaserJet 2500 Series Toolbox, which are only supported for Windows 98, NT 4.0 (HP Color LaserJet 2500 series printers with parallel connections only), Me, 2000, and XP.
Note The HP Color LaserJet 1500 Series Toolbox is not supported for the Macintosh operatingsystems. 1 Open the Toolbox in one of these ways: • On the desktop, double-click the HP Color LaserJet 1500 Series Toolbox or HP Color LaserJet 2500 Series Toolbox icon. • On the Start menu, point to Programs, point to HP Color LaserJet 1500 or HP Color LaserJet 2500, and select the HP Color LaserJet 1500 Series Toolbox or the HP Color LaserJet 2500 Series Toolbox. 2 On the Troubleshooting tab, click Diagnostic Tools (on the left side of the screen). 3 Click Calibrate Now.
Hope this helps!
Posted on Sep 01, 2009
komguy
  • 2306 Answers
SOURCE: I replaced both cartriges (Black and Color) and
You can dab the bottom of the color cartridge on a damp paper towel, check the streaks left behind, if there is no yellow either there is no yellow in the cartridge or it's just plugged. Dab it a few times on a wet towel, if still no yellow, you need another cartridge.
Posted on Dec 22, 2009
Testimonial: "Thank you. You were right on! Sadly enough, this is the second consecutive cartridge that was without yellow. Is this a common flaw from HP?"
Only printing Yellow
Sir/Madam
Please See The Vedio On Youtube
By This Time i Fixed My Problem,
HP 2500 color only prints yellow
or
Follow Us On
HP Printer Support
Jan 08, 2014 | HP LaserJet 2550n Printer
Copies print with a magenta hue. The color yellow doesn't print out. Tried 3 cartriages all the same. Clean printer also.
Try dabbing the cartridges on a paper towel, if you don't see a yellow line, the yellow is just empty, many have had the same complaint, new cartridges with no yellow inside.
Feb 01, 2010 | HP PSC 950 All-In-One InkJet Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
My Lexmark X2600 printer will not print. A notice keeps showing up on the screen, telling me that the color cartriage needs replaced before it can print. I just replaced the color cartriage. Can you help...
go to the printer properties option.their go to lexmark solution center .in that option there is a option to get your cartridge get selected.if you will not get your cartridges selected.it will everytime show you the option to replace the colour cartridge.
thanks.
Nov 05, 2008 | Lexmark Office Equipment & Supplies
Printing error (Canon ip1800)
replaced ink cartridges..error message appears now telling me to re align printer..can you tell me how to do this
Jul 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon I560s printer
Was this the problem prior to changine the cartriages? If not check the contacts between the machine and the cartriges. there may be tape, ink, papaer in between.
Jul 03, 2008 | Canon BubbleJet i560 InkJet Printer
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
Jun 11, 2008 | Office Equipment & Supplies
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
HP Photosmart A636 Compact Photo Printer Logo
13 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
