Question about Craftsman Garden
My craftsman lawn mower started fine I pushed it about 100 feet it died won't start has gas and oil got it last summer
    Habit-Forming:
    Scholar:
  • 54 Answers
Here is one suggestion,that may help. When mowing,did you hit something hard,like a root or maybe a small stump. There is a key to a key way under the fly wheel. The key has to line up with the key way for the motor,to run. This is a way that the motor is timed. This key is made to shear off if the mower hits something solid,this is to protect the motor crank shaft from damage. To get to the key,to check to see if has sheared,you must remove the fly wheel. If the key is sheared you will have to purchase a new key,any lawn mower parts store has them. If you don't have a part number,that okay,just give the model # of the motor and the horse power. The parts department can look up the key. If this is a problem,for you,than take the sheared key to the parts department,and they can match up the key,by actual seeing the key. Remember this,you must have some mechanical knowledge,when doing this repair work. The flywheel usually comes off with little effort,then again,on some fly wheels has to removed with a puller tool. I hope this helps. Sincerely,Brad Locke
Posted on Nov 23, 2015
5 Suggested Answers
  • 18 Answers
SOURCE: Honda HR 17 lawn mower dies after it starts
01 Fuel tank cap? Loosen it to see if it is plugged.
02 Possible fuel line obstruction? Disconnect at carb to make sure there is adequate fuel flow.
Posted on Apr 20, 2010
  • 54 Answers
SOURCE: Hello,
It sounds like a fuel restriction, check the siphon tube. Also make sure your oil isn't over full.
Posted on Apr 28, 2010
SOURCE: lawn mower cranck but wont start...
Since you already checked for spark and air I would drain all the fuel out of it and check that fuel for water. Over time some lawn mowers end up with contaminated fuel. You can see the water sitting on the bottom of the fuel if you let it stand for a bit in a small plastic bowl.
Be sure to empty and dry out you fuel can as well. Especially if the mower stopped running right after a refuel. Which is a good sign your gas can is contaminated too.
Posted on Jul 02, 2010
dan5268
  • 542 Answers
SOURCE: My craftsman push mower won't start, I changed the spark plug, I need to download the owners manual for help. The model @ is 917.373981
Here is the manual for your Craftsman
Posted on Apr 11, 2012
Why is my craftsman lawn mower keep shutting down every 5 feet or so. Its about 4 years old. Any suggestions?
Are you sure you have to mix the gas with oil.I don't think Craftsman engines mix the gas. It you have a dipstick that tells me that you put oil to the full mark on the stick. If your carb has a cup on the bottom of the carb take it off and clean it out. Also clean the fine holes out that's in the bolt as they get plugged with dirt.and engine won't run.Usually an air gun will do the trick. When you put it back together make sure the gasket is installed properly. If there is not much oil when you check it you could seize the engine.
Jun 29, 2014 | Craftsman Garden
2009 190cc Briggs starts but won't run
Ensure the oil is full. It has an oil low sensor. 30w oil.
Jun 13, 2013 | Toro Garden
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Lawn mower died while mowing and won't restart
check the carb and air filter... also make sure its not gas from last season and make sure the oil is good.
Aug 16, 2009 | Garden
18hp/ohv craftsman 42in wont crank
One thing to check, see if there is a piece of root stuck under the tractor there is interrupting any of the security features from allowing the tractor to start. It might be a small piece that stops a plunger from engaging.
Mar 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
77 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
