Question about GE Microwave Ovens
I have a GE Spacemaker LX1800. the start button does not work. Basically, its worth less. I think there is a problem with the control board. but don't know where to get it.
  • Anonymous Mar 18, 2014
    WHAT IS THE SPECS OF A G E MICROWAVE SPACEMAKER LX1800
  • GE Master
  • 9,098 Answers
It may be a failed keypad or control board, but more likely it's a simple failed door switch or loose or broken door switch mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
I would strongly suggest checking the door switches first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can see the switches & mounts and refer to these files
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Also, there should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I have a GE Spacemaker LX1800. the start button - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jun 24, 2009
Ge spacemaker II microwave started humming and nothing showing on monitor
My parents have had a couple of the spacemaker microwaves mounted over the range with the built-in vent. Over time, the seal on the control board gets a crack in it and the steam from cooking below it gets up into the control board and does it in.
Even if yours isn't mounted over the range, it sounds like a main control board failure.
Sep 10, 2016 | GE PEM31DMBB Black Profile Spacemaker II...
GE eterna spacemaker microwave won't heat
The problem is a magnetron, "heart of the system" or the inverter board, "if 7 years old or less" and possibly the keypad control board, all of these items are not cheap and lethal voltages are present.
May 05, 2012 | GE Microwave Ovens
GE micro died
The main fuse is the probable cause, magnetron, "heart of the microwave oven" the inverter board, "if 7 years old or less" and the keypad control board can be a factor.
Apr 21, 2012 | GE Profile Spacemaker Over-the-Range...
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave. Start and clear buttons do not work. The other buttons all work. What do I need to do to fix the problem ?
Hi. we do not have this brand of microwave in NZ but generally speaking, the problem can be weather/humidity related, the membrane switch is most likely the culprit or those two buttons can simply be worn (this is the button panel and it is a flat sheet with a ribbon tail which plugs into the control board).
It may or may not be availale as spare part.
In general it may not be worth repair. best to weigh up the cost of the part against a replacement machine
Aug 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
May 27, 2010 | GE Profile Spacemaker Over-the-Range...
I have a GE Spacemaker LX1800 that is not heating up the food. It acts like it was working normal but is not heating the food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]---=]
May 11, 2010 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker Microwave XL1400- No heat
The problem could be anything from a defective control circuit board or a burned out magnetron tube. Either fix is quite expensive and you'll have to evaluate whether you think the repair is worth the cost vs buying a new microwave.
Bear in mind that a fixed microwave is still a used microwave. So to get an apples-to-apples comparison you have to ask yourself, would I pay $XXX (substitute XXX's with actual repair cost) for my used microwave?
Oct 10, 2009 | Microwave Ovens
Microwave Ovens Logo
108 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
