Question about HP CP3525N Color LaserJet Printer
What does it mean when the printer says "Error 49C02".
Our HP Printer brings up the message "Error 49.4C02", we've tried to restart the printer but message keeps coming up.
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
komguy
  • 2306 Answers
SOURCE: hp laser 4000 keeps coming up w/ 41.5 error
41.5 is a paper feed error, take out the paper tray and clean the rubber roller above where the paper goes with a cloth just damp with water. Dirt on that roller will stop it from picking up the paper.
Posted on Jul 09, 2009
  • 59 Answers
SOURCE: error message 0x610000f6 won't re-set.
>try to do hardware reset
>while printer is on unplug power cord at the back of it, press and hold # and 6 buttons on your printer, while holding the buttons plug back power cord, printer should initialise you can release the buttons after 10 secs or until you see semi full reset on the display, if the printer will not automatically turn back on press the power button, if it ask for you to set the region and laguage again then you have done the reset successfully
>this hardware reset should clear the error otherwise better contact hp
Posted on Sep 29, 2009
  • 55 Answers
SOURCE: HP 8500 all in one printer: error 0x61011bef
0x61011bef is a general error that the chipset in the printer gives instead of a "carriage jam " error message.
Double check inside the printer as well to ensure that there is no bits and peices stuck insde the printer where the carriage assembly ( where the printheads sit) check to make sure that moves freely.
as well as clean the rollers on the back of the printer... silly yes but it has been know to cause an error if there is built up paper dust on them
Posted on Mar 27, 2010
  • 100 Answers
SOURCE: printer keep restarting. c6180 hp photosmart
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time. acca299.jpg
Posted on Oct 03, 2010
WHAT DOES ERROR 49.4a.04 MEAN
First step for any 49 error is to ensure that your printer has the current firmware installed. Unplug any network or USB cables and restart printer. If it restarts properly, print out the configuration page and check the firmware date and then go to HP.com and check the current firmware revision to see if it is newer. If it is install it on the printer.
Sep 14, 2014 | HP Office Equipment & Supplies
After working for years, my HP All-in-One Printer stopped printing jobs suddenly, giving me an "incompatible black ink cartridge" message on the computer & an error light on the printer;...
sometimes they just defect and burn out.. place and old/empty/dry one if you have, if the error disappear you now that your cartridge just failed and you need new one.
Sep 20, 2011 | HP PSC 1315 All-In-One InkJet Printer
Can anyone tell me what an error message 82.0180 means on an HP Laserjet 4100?
Error 82.0180 means that the JetDirect Firmware is corrupted. Refer to your manual how to cold reset the JD (JetDirect) card. JetDirect card enables network printing. If problem persist after cold reset, you may need to purchase a new JD card or bring your printer to HP service center for repair.
Aug 19, 2010 | HP Office Equipment & Supplies
What is solution of error oxd05d010d
Hi
This error means there is an internal error condition. To resolve this error remove the cartridges from your printer. Now wait for message "Insert the cartridges' to appear on the printer, as soon as the message appears disconnect the power cord from back of the printer. (Restart the printer if message doesn't appear) Now wait for a minute and plug back the power cord, if doesn't turns on itself then press the power button.
Insert the cartridges and check whether you are still getting the same error. If you are still getting the same error then try pressing # and 9 key simultaneously to reset the printer, wait for a while to let the printer complete the reset.
Daniel Scott
Jun 19, 2010 | HP Officejet 5610 All-In-One InkJet...
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Error message 0x610000f6 won't re-set.
Sep 28, 2009 | HP Photosmart Premium C309A All-In-One...
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
0xc19ac3ff error code
Same deal. Message "ink system failure". I restarted the printer, it works fine
Mar 07, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP CP3525N Color LaserJet Printer Logo
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
