Question about Ricoh Aficio 2015 Copier
Aficio 2015 ADF not working
Only copier is working ,while ADF is plug the machine is giving code The code is 0821.
  • 204 Answers
If you plug the ADF connector while the machine is on the code will appear when you connect the ADF shut down the machine and then connect the ADF plug
Posted on Jul 12, 2009
After replacing the main motor of my richo afico 2018 the copy result reduces is the cause of mismatch main motor?
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
Oct 05, 2013 | Ricoh Aficio 2015 Copier
Error code sc626 bicu and lct
try to check connectivity of this conjuction between lct unit and bicu like jack may be brocken and try to check adf jack is this disappeared it's come from adf attention: don't plugged or unplagged jack whil machine is working be carfull !!!!!!!!
Jan 29, 2011 | Ricoh Aficio 450 Copier
Hi my Ricoh aficio 2015 has a password on the system so i can"t do anything with it. we purchased this from a friend who doesnt remember the password. is there anything i can do to try and reset it?? I am...
enter SP mode. 2xfunction clear(yellow button) 107 hold down Red clear button. 1 to enter copier, 7 to enter data log, 810 to reset key operator code. Exit , This shoud work. If not give me a shout.
Aug 03, 2010 | Ricoh Aficio 2015 Copier
Ricoh Aficio MP 2000 ADF (auto document feeder) is not working
tape is on the underside of the ADF causing a sensor to not tell the machine that the ADF is in the lowered position. look under where the hinge area goodluck
Apr 22, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Jul 15, 2008 | Ricoh Aficio 2015 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015
Does your machine have a document feeder on it? If so, turn off and unplug the machine from the wall, and check in back of the machine to see if the feeder is plugged into the unit properly. Try reseating the document feeder plug to ensure good contact. Plug the machine back into the wall and turn it on. If it detects the document feeder, fax and scan functions should be restored.
Jun 16, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
241 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
