Question about PCS Tire Bike Cityatb 26 X 125 100 Psi Slick Blk 2pcs
Where can i find 26-27.5X1.125q100 psi slick tires?
I have made some changes in my canondale F7 mountain bike, and made them road bike. im looking for 26-27.5"X1.125/100 psi tires. can i get some recomandations, please?
Looking for replacement light alloy rims. 26" v2100 genesis mountain bike, ultra light rims 21 speed
What rim you need has too many variables (width of tire to be used, your weight, balance of road/off-road usage and roughness of off-road use, budget, etc.) that you have not mentioned for anyone to give an appropriate recommendation.
Secondly, unless the rims are both bent it's a waste of money and effort to replace them, as good quality rims and spokes alone (a new rim may need different length spokes) could cost almost as much as the original cost of the bike ($119), let alone when you add labor.
Finally, worrying about "ultra light" rims, especially on a bike that weighs 35+ lbs, is useless. Shaving off ounces when the bike and rider together could weigh 200 lbs. is not going to make it faster or easier to pedal.
Sep 28, 2016 | Mountain Cycling
Tip
Mountain Bikes Vs Road Bikes.Mountain bikes have become very sought after and...
Mountain Bikes Vs Road Bikes.Mountain bikes have become very sought after and furthermore are usually readily available. A majority of these bicycles will often be a lot more comfy in comparison to road bikes due to the fact that you ride with a considerably more erect posture. They are simply devised for going off the beaten street paths and into places like the rugged slopes as well as mountain tops. If one thinks about it, this is exactly how their name was derived. Fortunately they are usually larger than road bicycles, due to the fact mountain bicycles have to withstand the excessive abuse relating to traveling on difficult, bumpy paths. A lot of them include additional features for example shock absorbers, wide tires, in addition to straight handlebars. You will find there's a suspension system that produces a comfortable drive, along with the heavy, wide tires are generally more unlikely to slip in comparison to the slimmer wheels of the road bicycle. Specialized knobby tires intended for outstanding grip and also a complete suspension are crucial aspects of the design related to mountain bikes. The actual bikes will be meant for difficult and also tough landscapes. The bicycles are engineered to fulfill their unique intent as long lasting off road sports gear. The specific bicycle created for downhill biking is actually extremely well put together and will have the ability to endure high-speed driving on pathways customized courses. These kinds of styles of bikes have got to be continuously transforming as new technologies and material come into play. <br /><br />Road bikes are produced with a particular style with regards to speedy, lengthy traveling times. The particular frame within the bike is probably the most important element. A very important characteristic in terms of a road bike tend to be how heavy it is in addition to stiffness which decides where the actual energy from your pedal strokes is to be sent. Basically these two elements have a direct impact on how much power is being delivered to the bike chain and therefore the actual wheels. Due to this quality, racing bicycles must sacrifice ease and comfort to get top acceleration. Drop or declining handle bars tend to be positioned beneath the seat level to be able to position the operator in a much more streamlined and sleek posture. The exact driving positioning is actually trying to combat the wind resistant by having he rider be curled on the dropped handle bars. Both sets of tires are generally in close proximity to guarantee the bicycle presents quick and easy handling. In summary, road bicycles are perfect for a lot of types of riding however they tend to be dangerous on rocks as well as other non paved surfaces.
on Dec 21, 2010 | Cycling
Tip
Pump Them Up tip
Often Bicycle tires lose air slowly. It's just their nature. Because they don't hold a lot of volume of air and because that air seeps out over a relatively short period of time (a week for a road bike tire and about two weeks for a MTB knobby), there's a risk if you just ride without checking the tire pressure. If you bike on soft tires and you hit a pothole, rock or other obstacle, it's possible to damage or ruin, the tire, tube and worst of all, the rim. A too-soft tire also means that you're working a lot harder and on a mountain bike, it can make for a wobbly, hard-to-handle ride. So, be smart and check your tire pressure regularly: every week during the season for mountain bikes and before every ride for roadsters.
I have a Schwin Solution FS AL mountain bike. I would like to put road tires on it. It now has 50-507 (24X1.95) on the side wall of the knobby tires. What road tire would fit?
I have done a similar thing with my mountain bike. The first number is the size of your wheel. The second number is how thick your tire is. You can get any road tire that has a "24" in the first number of the 24X***. Depending on the number after the 'X' you will probably need to get an inner tube that falls within that size. Most of the inner tubes will have a range for that second number. If the number is too large the inner tube will not fit inside the road tire.
Jan 30, 2015 | Schwinn Mens Solution FS AL 24 Bicycle Red
Bike rim change 26x1.95 to 27x1.25 on Mountain bicycle
If you're saying you want to keep your old hubs and install roadie-sized rims so you can use road-friendly and efficient tires you're looking at an expensive and wasteful project. The hubs would be the only parts that are potentially re-usable. I seriously doubt the rims you have right now are 1.95" wide. I have several mountain bikes and many wheelsets and not a single one that I can't put anything from 26x2.25 to 26x1.10" tires on. At 100-plus psi the little tires are hard as rocks and roll nice.
If you DON'T have disc the whole project is a non-starter becuase you can't arbitrarily change wheel sizes on a rim-brake-equipped bike. Disc brakes would require you to have disc-specific hubs so search the web for "700c disc wheelset" that match your disc size (if you have disc).
If you want to DIY you'll need some special tools and skills.
http://www.parktool.com/blog/repair-help/categories/wheel-and-rim-service
Then you'll have to select rims and find an online spoke length calculator so you can order the precise lengths you'll need, assuming you have data for your rims and your hubs.
Look online or eBay, too.
A Bike Shop might be willing to lace on new rims and spokes to your hubs but it will be expensive and you would be destroying presumably fucntional MTB wheels. By the time it's all ordered and installed it would probably have been cheaper and more reliable to have just purchased new wheels.
Jul 19, 2011 | Cycling
How much fuel does a yamaha serow 225 WE consume per km?How long should i take to replace engine oil?what is the best engine oil type do you recommend i should use?What are the rite pressure units for both...
Your Serow should get around 70 Miles per gallon (28 kilometers per liter). I find that the oil in my bike is thrashed after 1000 miles of riding. It only takes one quart of oil to change it so that is probably the best interval for a single cylinder dirt bike. In you case every 1600 to 2000 kilometers. You should use only a JASO MA certified motorcycle oil. 10w-40 for cold climate/year round. 20w-50 for warm climate/touring. Car oils use different additives and may cause scoring in certain types of cam bearings. Do not use any oil that says " Energy Conserving " on the label . It will shorten the life of your wet clutch and transmission gears. If you choose Synthetic oils, they will help your bike run cooler and shift easier. Shell Rotella T and Rotella T Synthetic 15w-40 are inexpensive JASO MA oils. Trials bikes use tire pressures around 10 PSI (.7 kg/cm). Lower pressures are used for better traction off road. Street bike tires run higher pressures around 30 to 35 PSI (2.1 kg/cm to 2.4 kg/cm)for road driving. This gives better cornering and tire wear. For good all around performance for on/off riding you probably want to run 25 to 30 PSI (1.8 kg/cm to 2.4 kg/cm). For mostly street use 30 to 35 PSI (2.1 kg/cm to 2.4 kg/cm). There is probably a sticker on the frame near the side cover that tells you the factory recommended tire pressure for your model. Ride and make adjustments from there.
Jun 14, 2011 | Yamaha XB32 Motorcycles
Hi, I owned a 2011 Trek 7.6FX. So far the bike has been good and in stock condition but I was wondering: 1. If I could use a fatter tires like LT2 or LT3 if I were to hit the track. The 700x28c...
"Track"??? Do you mean "trail", as in REAL off-road rocks-n-roots singletrack?
Ah, the 'compromise' bike dilemma. This is NOT a mountain bike frame nor are the wheels designed for hard hits. But you could try to make it work for light-duty trails.
http://en.wikipedia.org/wiki/Bicycle_wheel
1. They make all kinds of rubber for 29ers which use the same rim size. Search for 29er tires.
The frame and fork may limit how large a tire will have clearance. Being totally stiff (unsuspended) the off-road ride would be rough by today's MTB standards. Think: loose fillings and blurred vision, plus a lot of standing to survive the ride. That takes energy. But then there are those who have intentionally bought 'niners without suspension for some reason.
A REAL mountain bike would be a better choice, just as a REAL road bike might be for that activity if sustained speed is ever a going to be a goal.
2. Avid's make good brakes AND levers. Which end is the problem, I wonder. Pads also play a major part in stopping power.
May 27, 2011 | Trek 7.6 FX WSD
How to Maintain a Bike's Tire Pressure for Good Performance?
Buy a good floor pump with a gauge (see "How to Buy a Bike Pump," under Related eHows). A small, frame-mounted pump is useful only for roadside repairs.
Understand that it's normal for most tires to lose up to 10 pounds per square inch (psi) per week. This does not mean you have a slow leak.
Look on the tire's sidewall for tire pressure recommendations. Don't exceed the maximum tire pressure listed.
Inflate your mountain bike's tires to 40 psi for dirt riding. You may wish to inflate your tires to 50 to 60 psi for city riding.
Inflate your road bike's tires to 100 psi for road riding. Some road tires have much higher psi ratings. However, 100 psi will provide a good mix of performance and comfort.
Inflate your hybrid bike's tires to 60 to 70 psi for city riding.
Check your tire pressure before every ride
Can you put mountain bike rims or wheels on a road bike?
Yes, but not without consequences. The front wheel will probably fit, but the brakes won't reach the rim and it's likely that the tire will get squeezed by the fork.
A modern rear MTB hub is 135 mm wide, while a modern road hub is 130 mm, so there's your first problem. Then you'll also have the same issues with brakes not reaching and tire clearance as you had for the front.
Bikes with disc brakes can sometimes take different wheel sizes w/o any further issues, but keep in mind that pedal clearence will change.
Dec 16, 2010 | Cycling
PCS Tire Bike Cityatb 26 X 125 100 Psi Slick Blk 2pcs Logo
32 people viewed this question
Top PCS Cycling Experts
John Egan
John Egan
Are you a PCS Cycling Expert? Answer questions, earn points and help others
