Question about Saeco Aroma Espresso Machine
New Saeco no water flow to prime, quick steam then nothing
mirran
  • 515 Answers
SOURCE: I have a Saeco Incanto
Do you have a filter in your water tank?
if you have a filter, remove it and try.
Posted on Jul 10, 2008
EsWorld
  • 1618 Answers
SOURCE: Saeco via venezia coffee machine wont prime
Turn machine on and make sure that the knob is fully opened, if the pump does not engage(vibrate) then either the machine is not getting power or there is a problem with the pump.
Posted on May 16, 2009
  • 1089 Answers
SOURCE: I have Saeco Royal Coffee Bar. Hot water and
Hi
You may have a flow meter that is bad. If its white plastic check for corrosion at the wire terminals. If your have corrosion change the meter and you should be good to go.
Posted on Jun 01, 2009
EsWorld
  • 1618 Answers
SOURCE: My Saeco Odea has the red ! light quickly
Open the steam valve and make sure the selector is set to hot water.
Posted on Jun 30, 2009
  • 10 Answers
SOURCE: Saeco Via Venezia STEAM
exchange it...
Posted on Aug 02, 2009
Initially when the unit said need to prime, no water would flow out of the steam unit. After pulling the pump out and cleaning it, not sure what was blocking water the steam unit now has water pressure,...
I fixed the same issue by pushing in the water knob "in" towards the machine. Machine than primes normally as the water flow is restored and it resets itself.
Dec 13, 2010 | Starbucks Saeco Italia Digital Barista...
My saeco incanto will not make steam. Instead upon opening the valve, the pump works for a few seconds the fade like it has lost prime, and then the displays reads "ventilate" after this, the...
Its probably the flow meter. If a debris gets into the receptical on the back when the water tank is removed, it flows to the flow meter and restricts or plugs the intake. Then when you try to flow water the pump tries to **** water but nothing moves and the turbine in the flow meter does not spin, telling the computer that it needs to be ventilated. Clean or replace the flow meter and you should be good to go. Remember, when you have the water tank off don't work on the beans and when your filling the water tank, do it off the machine so you don't contaminate the grinder.
Nov 05, 2010 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
New Saeco Villa Espresso won't Prime
check your steam wand and you can check does water get true to the pump,maybe you have air in hous
Aug 29, 2009 | Saeco Spidem Villa
Brand new Saeco Villa machine won't prime
Press hot water button then open valve, then push the valve knob in if that works take it back and tell them that the valve is damaged.
Aug 29, 2009 | Saeco Vienna SuperAutomatica Coffee...
Ventilate shows.
try prime water on steam valve couple minuts if you have again message ventilate,that can be two reason,or your flow metar doesnt work or cpu board,but you try first prime water.
Aug 28, 2009 | Saeco Royal Professional Espresso Machine
Hi
Apr 10, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
Via Veneto will not prime
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Sep 18, 2008 | Saeco VIA Veneto Espresso & Coffee Maker
Prime it
1. Open the steam knob all the way.
2. Turn on the pump (coffee Button)
3. Turn on the power to the machine.
The machine will start to pump hot water out from the steam wand. When you get a steady flow, your machine has been primed.
For Descaler, Cleaners and Parts for your saeco machine visit
www.CeriniCoffee.com
May 28, 2008 | Saeco Classico Espresso Machine
Coffee Makers & Espresso Machines Logo
103 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
