Question about Bosch Ovens
Neff b45m42n0gb oven
The door handle has become very loose and unable to tighten. There are 4 screws which I removed from the door but the glass sheet doesn't seem to move. Any ideas?
SOURCE: Loose Oven door handle
can get spares from
Tel. 01628 620081 Fax 01628 776345 - Spares Email is spares@a1tech.co.uk
Posted on Apr 14, 2008
yalmer
  • 552 Answers
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Posted on Jul 02, 2008
mastatech
  • 478 Answers
SOURCE: Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Posted on Mar 12, 2009
paul4265
  • 592 Answers
SOURCE: The handle is loose on my kitchenaide superba oven
The glass portion of the oven dorr is not only attached by the screws, but there is a procedure to remove the door from the stove as well.
1: Open the door all the way.
2: On the hinges is a flip latch, flip them both up.
3: Close the oven door as far as it will shut, leaving the latches flipped up.
4: Lift up on the oven door evenly and squarely, lifting up and off hinges.
{note}...DOOR WILL BE AWKWARD AND HEAVY!
5: Place on flat surface, and under the bottom of door should be retaining screws for the door skin, so as to allow for removal of it as well. This should give you access to the handle so that you may tighten it.
Then go in reverse order to put door back on, making sure to flip hinge latches back down after re-insertion of door onto hinge pins, as the door will not shut without them being flipped down.
Posted on Jan 20, 2011
  • 196 Answers
SOURCE: my neff oven's handle has become loose. I cannot
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Posted on Mar 02, 2011
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
How do I tighten a loose handle on a Neff u1661n2gb/05 double oven
There are no screws holding the glass on. You need to pull off the inner glass. It just clips on so just pop a round knife at the top and it should just pop off. Tightening the screws should be easy but you probably need a torx screwdriver from memory
Mar 08, 2015 | Neff U1661 Double circotherm super...
How do I replace the handle on a neff oven?
1. Fully open the oven door.
2. Move the catch levers on the right and left-hand sides to the fully open position.
3. Placing the door at an upward angle toward you, grasp the door with both hands and lift it out of the hinges toward you.
4. undo the screws in each Connor & lift out the glass.
5. do the same with the handle screws, then put new handle on.
6.repeat above steps backwards.
Aug 30, 2014 | Neff Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
The door handle of my oven whirlpool gold model no GGP84803 is loose I try to get it off by prying it from the top with no luck seem to be jam or locked I am not sure how to proceed.
I had same problem, fixed by removing screws under door and removing side panels . Then remove front glass ( 4 screws under glass ) and remove other screws behind glass to remove handle and then tighten 4 screws on handle. Works great.
Dec 29, 2009 | GE Ovens
Mar 12, 2009 | Ovens
Loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Jan 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
21 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
