Question about Honeywell Heating & Cooling
Is the th 320 programmable - Honeywell Heating & Cooling
My White Rodgers 1F78 programmable thermostat shows a constant room temperature of 83-84 in the afternoon, but I set it at 77 throughout the whole day and night. Should I get a new one?
It sounds like the temp sensor is defective in the T-stat. I would replace it, get the newer programmable ones, they are very reliable and very cheap to buy online.
Sep 21, 2016 | WHITE-RODGERS DIV 1F78-151 White 70 Series...
What is the Hz for the Panasonic 42" TH-42A400Z ?
This tv was intended to be used in New Zealand. It is rated 50/60 Hertz. Just google the user manual and you can see that the retailer told you a fib.
Regards,
Joe Van Buren
Aug 02, 2014 | Panasonic VIERA Televison & Video
Auto set up finds only some of available programmes. Only ITV channel found is ITV 4. cHANNELS 4 AND 5 not found. Very good reception on programmes it has found. Full range of programmes viewable...
It maybe that the TV needs to be completely reset. in the menu somewhere should be a setting to "restore factory settings" or "reset to default" something like that...
Try this and post the results...
Aug 27, 2010 | Panasonic (TH-50PZ700U) Television
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Lost power cord
Should be OK as long as it's capable of carrying the wattage the system is pulling. The TH-42PX60U is rated at 320 watts max - you should be OK as most computer cables are rated well above that. However if you're worried, us the power cord from a laser printer or copy machine - it will definately carry the load.
May 12, 2008 | Panasonic TH-42PX60U Television
Manual
This site has the Explorer 320 manual:
http://www.plantronics.com/media/media_resources/literature/user_guides/explorer320_userguide_en.pdf
Dec 11, 2007 | Plantronics Explorer 320 Wireless Headset
Heating & Cooling Logo
27 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
