Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
What water filter is needed for ed5gtn - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
Side by Side Model # ED5GTN It is not staying cold - freezer let everything defrost and fridge not staying cold.
Open the freezer door and listen for the freezer fan . If you do not hear the fan , tap on the refrig thermostat knob mediumly . If the freezer fan comes on , then the thermostat is bad , pt # 2198202 which is located behind the knob . If you DO hear the freezer fan , then the overload / relay on the compressor is bad which is pt # 8201786 ( comes with instructions ) . Both are easily repairable . If any problems , reply back for more help .
Aug 03, 2010 | Refrigerators
Water tastes funny
if there filter was not properly installed you would not have any water at the door.
you do not need to turn the water supply off to change the filter.
you should be able to push the filter light for three seconds,they do not turn off they just change color
May 28, 2010 | Samsung RF265AA Bottom Freezer French Door...
I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset light. (This light will tell you when to replace the water filter.)
press the button to the right of water filter to release filter...
Sep 17, 2009 | Refrigerators
Need to remove the drip pan under my Kenmore side by side fridge.
Mine is a whirlpool side-by-side ED5GTN which must be the same design as your Kenmore.
There is no way the drip pan will come out without tilting the refrigerator backwards.
The tape is removed, the foam packing, the filter removed, the pan is not flexible enough because the pan broke.
I have worked on this until my hand is bleeding from struggling with this poor design. Custumer service was no help..said, "Well, I don't know."
I'll wait for help to tilt the thing because there is black mold and I want all removed from the bottom of the refrigerator. This design is not only "NOT customer friendly but unhealthy for your home."
Jun 22, 2009 | Kenmore 44273 Side by Side Refrigerator
Whirlpool refrigerator model ED5GTN cooling problem.
go into the lower rear compartment and check if the compressors hot. if so unplug , get a soaking wet hand towel and place it on top of the compressor for an hour.
then try plugging back in.
check condensing coil by compressor and clean if needed.
Phil
Apr 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Using without water filter
The effort it would take to eliminate filter would be too much. Just leave filter in place. If new house filter is working right you should never have to replace fridge filter and your water will be double-filtered :)
Jul 02, 2008 | LG LSC26905TT Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
23 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
