Question about Pool & Spa
I need to purchase an Emerson 1563 spa motor
Cat.no. 9352-9303-A Model K55MYGRD-8367 1/15 hp. 230volts
2 Suggested Answers
SOURCE: I need to purchase a Emerson 1563 spa motor. Cat.
This place has them:
http://www.affordablespasandparts.com/Aqua-Flo-CMCP-R0-1-15-hp-230v-1-spd-02593001-2010GK.htm
Posted on Oct 26, 2011
Where can I find a diagram to fix a pump K55MYGRD-8367
this can be a hard pump to service. but you can remove the front pump housing and see if you can remove the impeller by hand, the back of the motor will have a screwdriver slot in the shaft to hold the rotor still while attempting to unscrew the impeller. after removing impeller you will need to remove the 4 thru bolts this will allow you access to the ceramic portion of the shaft seal assembly.
replace all needed parts and reassemble. never run pumps dry always prime the pump with water.
doing this job can save you a bunch of money and usually cost about $150 at my shop.
Jay the pool pump repair guy Longwood FL.
Jun 26, 2017 | Emerson Pool & Spa
What size capacitor is in the 9352-9303Emerson spa motor?
Try using the values listed on the one on/in the motor.
Sep 11, 2014 | Pool & Spa
Spa pump k55mygrd-8367
Most common and likely situation with this,... mechanical pump shaft seal has failed. This allowed water to enter into the electrical motor and lubrication from the front bearing had been washed away. The purpose of the shaft seal is to keep the water OUT of the motor!
Now as motor spins, bearings with less lubrication gets a lot hotter!
And... When metal gets hot, it gets soft! What was once perfectly round and lubricated, is now getting oblong or square and not lubricated. Square bearings don't spin well and are not as quiet as round bearings! Hence your loud noise. Oil on the shaft will do nothing. You either need to replace both bearings, front and back, and absolutely replace the shaft seal or, replace the motor and the shaft seal.
Jun 02, 2014 | Emerson Pool & Spa
Spa pump leak
Failed Mechanical 'Pump Shaft Seal'
Apr 13, 2014 | Emerson Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
Emerson 1081 1563 R63MWENA-4727
should tell on old motor if tag is gone contact manufacturer
Oct 30, 2013 | Pool & Spa
I have a emerson 1563 spa motor and need a new terminal board, anyone know where I can get one or have a cross reference number for it,
search your area for YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING .he might have one to give you .pictures are nice to have. jay
May 18, 2011 | Pool & Spa
I need to purchase a Emerson 1563 spa motor. Cat. 9352-9303 Model K55MYGRD-8367 hp 1/15 and 230 volts. Can you help me?
Jun 27, 2010 | Pool & Spa
My emerson spa circulation pump 1563, model k55mygrd 8367 quit working. Can, 't find replacement.
Is this pump for a 'in ground' body of water or for a fiberglass spa?
Someone MUST make something similar.
If yours is in ground you have many options based upon your filter media and the size of the suction and discharge lines.
If you can give me more information, I can more than lilely answer your question.
Let me know ... I want to help
a
Oct 10, 2009 | Pool & Spa
Pool & Spa Logo
44 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
