Question about Samsung 4.3 cu. ft. VRT Plus , Steam and PowerFoam Front Load Washer
How to remove inlet water screens - Samsung 4.3 cu. ft. VRT Plus , Steam and PowerFoam Front Load Washer
Why is my machine flashing a tap sign and stopping?
Hi and welcome to FixYa, I am Kelly.
Turn off the water at the wall connection and remove the water hoses from the inlet water valve. Remove the inlet screens and wash them under slowly running water by rubbing your fingers over them. Reinstall the inlet screens and re-connect the water hoses to the machine. Remove the hoses at the wall connection and make sure the installer has not installed inlet screens on the hoses. If there are inlet screens on the hoses also clean the inlet screens. Then reconnect the hoses.. turn on the water and test for leaks then test the machine.
This should get you going unless you have relly low water pressure in the home.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Hotpoint WMA74 Front Load Washer
I am getting the error code "HC" since we replaced a hot water heater. What does it mean? How might I correct this? Whirlpool Cabrio
There is most likely debris from the plumbing repair / install of the hot water heater that has migrated into the inlet screens of the washing machine. Turn off the water supply. Remove the water hoses from the water inlet valve and then use a thin bnladed kinfe to coax the inlet screens out of the inlet water valve body. Wash then under slow running water by gently rubbing your fingers over them until they are clean. Hod the screens up to a light source to make sure you have them totally clean. Reinstall the CLEANED screens and connect the water. This should correct the HC code.
If not there is one more series of steps to do:
- Water supply OFF
- Remove both hoses at water valve inlet
- Remove the inlet screens
- Reconnect BOTH hoses to the inlet water valve.
- Remove ONE hose from the Wall water supply and place it in a bucket TURN ON THE REMAINING HOSE connected to the wall.
- Start a WARM fill cycle and tap the water valve hose connections with the HANDLE of a hammer or the head of a very large screw driver while the unit is filling. (15 seconds)
- Stop fill cycle and turn off water to connected hose
- Reconnect removed hose to the wall connection.
- Reverse hose positons and place 2nd hose in the bucket. Thern ON the hose still connected to the wall.
- Start a WARM FILL cycle.
- Gently tap the water valve hose connections 15 seconds
- STOP Fill
- reinstall inlet screens and connect all hoses.
- test fill cycle and return to normal service
I am Kelly
Mar 16, 2011 | Washing Machines
I have a top load kenmore washer the spin cycle works but it wont fill up with water.
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. Here is a video at that will walk you thru the testing a water inlet valve. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Oct 06, 2010 | Kenmore Washing Machines
Washer takes a long time to fill up on any cycle hot or cold whats its problem?
Oct 05, 2010 | Roper RAS8445KQ Top Load Washer
No cold water to machine.
Oct 05, 2010 | GE WBSR3140DW Top Load Washer
Hot water will not flow into machine and cold sometimes trickles and sometimes flow
Oct 02, 2010 | Kenmore Washing Machines
I have a Westinghouse washer model # WWS833ES0. It will not fill with cold water.. only hot. And it does not fill any water on any rinse cycle. Any ideas as to what parts I will need to fix this? Thank...
Sep 27, 2010 | Westinghouse Washing Machines
Water will not fill into washer
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
May 18, 2010 | Washing Machines
Hot water goes into the washing machine. Cold does not
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. If the buzz is coming from the solenoid replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
May 07, 2010 | Whirlpool LSR7333 Top Load Washer
My washer keeps filling with water in the off position at first the cold water would barley run and know it runs slow all the time in the off position it's a roper washer
Your water inlet valve has probally failed.
Apr 07, 2010 | Roper RTW4300SQ Top Load Washer
Samsung 4.3 cu. ft. VRT Plus , Steam and PowerFoam Front Load Washer Logo
29 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
