Reading cd how is this done once cd is in the laptop appropriate space?
    Problem Solver:
  • 12 Answers
It depends on the system's settings. By default most computers will read a CD/DVD as soon as it is placed in the CD/DVD drive.
If this setting has been changed then open your file manager (Windows Explorer not Internet Explorer) and navigate to the drive (Usually Drive D)
If this fails then your drive may be damaged,
You can check this. For Windows right click on My Computer, choose Properties then Device manage. Find the entries for CD/DVD drives. If you see an ! or ? alongside the Drive name then their is a physical problem with that drive. Right click on the drive and choose Uninstall. Restart your computer. If all is ok Windows will reinstal the drive. If it doesn't then assume the drive needs replacing.
Posted on May 20, 2014
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
How to make CD Rom run as BOOT? please key in
Go into the BIOS and change the boot startup device order. Make the CD the first boot device and the hard disk the second boot device.
If you do not wish to change the BIOS you may select the CD drive as an alternate boot device by pressing F10 or F!2 as the laptop boots up to bring up a list of devices to want to boot from, select the CD drive and the follow the screen prompt.
Aug 29, 2011 | Dell Inspiron 1525 Notebook
I cant repartision my c drive which have 421gb space when i try to partision it shows that max partision is over is it possible to partision again and also i cant install many softwares such as ms...
i can help you do that....but you need to be prepared to make a backup of all data in the PC....befoe doing this.....once done....
use another PC to make a boot CD with KillDisk utility in it....go to my shared drive(it's safe)....click the lik below..... and get the killdisk application
http://www.4shared.com/file/10UH3hc2/boot-cd-iso.html
it's a zip file...use winzip to unzip it to Desktop....the folder has 2 files...first read the Readme file...
it has all the inst to how to use it....
insert a blank CD in the CD drive...
click the file ISO-Burner
leave the default value there....the "Boot-Disk" is auto selected....just click Burn ISO
Once done...insert this CD in the PC that need to be wiped clean....
ensure that the boot seq in the BIOS is set to CDROM as the 1st boot device...
let it boot and let the killdisk utility begin....
follow on screen instructions there.... and wipe the disk....
time taken for a 80GB disk is aprox 4 hrs...so calculate your time...if your disk is partitioned you need to run it for each partition....
visit my website
www.sureshayyar.110mb.com and visit the Quick Fix page....it has all details on how to format and install windows....
all the best
email me how you did
regards
Kris
suresh_krishnan1961@yahoo.com
or
krishnan_sk@bol.net.in
Mar 01, 2011 | Computers & Internet
I put in a disc and no options are coming up on the screen and the disc is not reading burning nor burning cd
Try and access the CD-ROM drive from My Coputer folder. If the CD can be read, that means that auto run is disabled on your system. If still you cann the read the CD, then there is a problem with your CD-ROM drive. Try cleaning the CD-ROM drive lens with the appropriate cleaning kit.
Aug 07, 2010 | Computers & Internet
Blank Disk Show Problems
This is normal. A blank DVD has no filesystem on it, so the OS can't give you any other answer.
Once you burn a filesystem on the DVD, you should see the appropriate space value in Properties.
Jun 17, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
NEED TO READ AND WRITE TO SAME CD WITH 2 DIFFERENT COMPUTERS.
You can't. You have to install Excel onto your computers. You can then use that programme to create files, which in turn you save to your computer hard drive.
Once done you can write CD's , DVD's or more popular for file transfer a USB flash drive.
Should you wish to continue with CD's, then I suggest you use CD-RW (Re-writeable CD's)
Jun 06, 2010 | E-Machines emachines (emachinees) CD-ROM...
On my dell inspiron 5160, I can play cd & dvd, & record cd but can not record on blank dvd, Roxio says drive is empty and no space?? I have fixed graphics card and reinstalled xp, hope you can help...
Are you sure it is a DVD writer, the specs for this laptop has a number of different drives one of which is a DVD/CD combi drive meaning it can read and write CD's but only read/plays DVD's.
Check the drive fascia if it says DVD-rom then it only reads them.
May 04, 2010 | Dell Inspiron 5160 Notebook
It can't read or burn any data on any empty disks (CD-Rom/DVD)! but it can read any other written disks like: programs , Movies , audio disks , data disks just when I put a blank or Empty disk it seems...
Some CD burners are either "+" or "-" or both "+ -".
That said you will have to check what type of burner you have. Example, you cannot stick a "+" blank cd into a "-" burner, and visa versa.
However, if your cd burner can read and burn both types, you should be okay.
Sep 25, 2009 | LG SecurDisc 8x External Double-Layer DVD...
After burning my copied cd showing free space:0 ,i tried 5 cds ...same problem
it says free space 0 because it doesn't want you to add anymore files to it because it's most likely a burn once. it says used 700mb because again, it doesn't want you to add anymore files to it because, again, it's a burn once. do you get it?
Mar 10, 2008 | Computers & Internet
Only reads some disks.
Hi, if the PC's are older than 3 years or the cdrom drives are near it's end of life, it will make problems to read some CDR's. If you recorded the CD's you are trying to read, try recording at less than 4X speed.
Sometimes, even "original" or "silver" CD's will make problems because they are not recorded correctly at the factory.
If the problem is with a CDRW drive, it applies the same theory, the recording laser is damaged or used up. It will not record a legible CD or DVD even if the software says that the record operation ended successfully.
Feb 09, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
David Payne
David Payne
