Question about Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red
Noise when weight on left wheel of mobility scooter
  • Electric Master
  • 1,198 Answers
Hi tighten youre axle nuts ...cheers
Posted on Aug 08, 2015
Pride ultra making noises during ride
If you turn to the right and the speed of the clicking sound goes faster then your left wheel has the problem. The shaft key is a little loose and is shifting while running. If you turn to the right and the speed of the clicking sound goes slower then the right wheel has the problem. Sometimes a stick will become lodged underneath making contact with the wheel or rim making a clicking noise. These noises can drive me nuts. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Jun 01, 2016 | Pride Health & Beauty
My gogo ellite scooter back wheels wont move its like they are stiff everything else working
Possible problem with your Transaxle or Solenoid Brake. More likely to be the Solenoid as this would explain there being no noise when you push it (in order to push it you have to disengage the solenoid hence no noise). This is a small magnetically operated brake attached to the end of your motor and they can sometimes bind on causing noise - heat buildup and excessive battery drain amongst other things. they usually are held on with 3 or 4 small allen bolts and are very easy to replace .. Hope this helps
Thanks Dave .....
Aug 28, 2014 | Pride Mobility Products Go-Go Elite...
Squeaking axles
It's almost certainly a slightly binding brake, it often happens, especially if you have a sticky hand brake cable/ leaver. I've posted a full answer here as another Pride post.
Jun 10, 2014 | Pride New Mobility Victory XL 4 Wheel...
Mercury prism mobility scooter
The distance a scooter will go depends on the size and weight of the load also. If two people are different height ( wind drag ) and different weight or there is a difference in load you are carrying then there will be a difference in how long the charge will last. Since you switched the batteries with no change then this could be the case. There are other factors that can cause this as well , such as brake dragging, wheel bearings going out, low tire pressure if your tires are air, if 4 wheel scoters then wheel alignment. hope that helps.
Jun 06, 2013 | Health & Beauty
The motor on our brand new Revo 3 Wheel makes a ticking noise about every revolution of the wheels. This is our second Revo, the company exchanged the first one due to the same problem that they could not...
Trent I had this with another scooter and it turned out to be a cut or piece missing from one of the tires. Check all the tires carefully for any little defect or gouge. If you find something fishy take a piece of tape and cove the defect and the drive the scooter and see if you still hear the ticking sound. If that doesn't help block the rear of the scooter off the floor and have your wife run it slowly carefully listen to both rear tires to see if you can find the one making noise. If you can't hear the noise block up the front tires spin them to listen for the sound you are hearing. Hope this helps and let me know what you find Good Luck
Oct 01, 2010 | Pride Mobility Revo 3 Wheel Electric...
Rubbing noise rear end but not all the time
Hi.Most scooters use a steel key in each rear hub to drive the wheels. These often get noisy. As the wheel turns the weight is put on the key and then comes of as the wheel keeps turning making a noise each revolution of the wheel. To repair remove the rear wheels and wipe a thin smear of grease onto the axle and key. This will reduce the noise. Hint, loosen the bolts holding the wheel on before raising the rear end to remove the wheels. If you place a support or block of timber under the machine, be careful of the motor brush holders.
Other noises could be gearbox gears worn.
Good luck. Neil.
May 20, 2010 | Invacare Supply Group Invacare Lynx Large...
Wheels- knocking noise in the right wheel
Hi. If the knocking noise happens with each revolution of the wheel, it is probably the square key in the axle that drives the wheel. Remoce the wheel and wipe a light smear of grease on the axle and key where it fits inside the wheel. As the wheel normally rotates, the weight comes on to the key and off again, causing the noise. The grease allows it to move without making the noise. Sometimes also caused by a stone in the tread, but most likely to be a dry key.Good luck. Neil.
May 08, 2010 | Pride Mobility Products Go-Go Elite...
Hoveround steering
You may want to check the bearings in the casters, that can cause a scrubbing noise and cause the chair to not turn well.
If there is a chirping noise, that may indicate a motor failure. There is a left and right motor, so if one is not working well, it can cause the power chair to not drive straight.
Jul 05, 2009 | Electric Mobility Power Electric Scooter...
Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red Logo
151 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
