Question about Sanyo Split System Air Conditioner
Sanyo sap 120 - Sanyo Split System Air Conditioner
I need the remote code for a sanyo SAP K3030AH air condotioner
hi, most universal remotes do not program to air conditioners. you need to contact Sanyo and see if they can provide you with a new remote.
Nov 28, 2012 | Sanyo Televison & Video
How do I turn off the SAP? My mom somehow turned it on and now only gets sound on some of her channels and some in spanish!
U have the original tv remote?Yes.Look for it on the remote for a button that said SAP pushes to turn it off.If u don't have the tv original remote,might could also be turn it off inside the tv internal Menu functions setup,but probally not because the SAP design in tvs are mostly just a SAP button on the tvs original remote design only.Try website like Remotes.com to buy the tv original remote.
May 10, 2011 | Sanyo DS32224 TV
Hello, I have a split system air conditioner (one of SAP-K181AA or SAP-K241AA or SAP-K251AA) and it is dripping cold water inside onto the floor. Can you help.
try to unclog drain line of your ac.or check the elevation of you indoor may be the drain water cannot flow smothly.
Jan 30, 2011 | Sanyo Heating & Cooling
Need user manual for sanyo SAP C95AH5
The sanyo service center has stopped the manual for this model.But there is one on-line site dealing with the service manual.You will have to place an order for the service manual on this site and you will receive the manual. This is the direct link for the online site dealing with the service manual of your sanyo product. just click on the link below:-- http://www.nodevice.com/manual/sanyo/sap-c95ah5-szip/get74707.html To receive the service manual you will have to register on this site and place the order.Registration will hardly take any time. ------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 17, 2010 | Heating & Cooling
What is sap and how do you turn it off
SAP is an alternate audio program usually seen in markets with different languages. The most common is for a Spanish broadcast of an English program. It is also used to provide audio descriptions of programming for the blind. There should be a menu option under Audio to turn this on and off.
Dan
Mar 03, 2010 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Several of my channel have no sound and I don't know how to adjust to get audio.
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12 digitalchangeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
Nov 22, 2009 | Sanyo Televison & Video
Have purchased premises with a sanyo sap-k302ah split system air conditioner and the previous tenant cannot locate instruction book on how to operate can you help me out with one please Maxine
There you go
http://service.airwell.com.au/airwellsanyoparts/Website 2007 update/sanyo/SAP-C302AH/sm700568-00_11 service manual.pdf
If you cannot veiw please let me know and i will re post the link or email it to you
thanks for using fixya
Apr 22, 2009 | Heating & Cooling
VCR Help
SP means Standard Play. Generally that is the Normal speed at which a VCR Records or Plays back a tape. SP is automatic, as it is the Standard setting. If you wish to record more picture than the normal 120 mins on a tape, then you choose LP (Lond Play) oe EP (Extended Play).
Nov 20, 2007 | Sansui VHF6010 VHS VCR
Vcr spanish language
You may have your SAP settings turned on in your VCR. Check your setup menu and turn SAP off SAP stands for Secondary Audio Program, it allows for bilingual sound if the station is transmitting a SAP signal. Thank you,
Aug 27, 2007 | Sanyo VWM-900 VHS VCR
Sanyo  Split System Air Conditioner Logo
13 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
