Question about Raymarine GPS
I have a Raymarine C80 installed on a Chris Craft Cataline 23. Thru-hull transducer. No radar. I have a chart cartridge which is correctly installed. My problem is with the chartplotter function where the unit seems to randomly "lose" the ability to display any chart details or contour lines. When zoomed in to the range I would normally use, no details are visible and shoreline looks like it was drawn with a ruler. The electronic tech at my dealer toyed with it a little and it worked fine. Next time I got on the boat it was back to the same problem.
  • john_leon104 Jun 22, 2009
    The problem can occur while the boat is at the dock (no vibrations or pounding from being run) and has not been resolved by a master reset.
  • 11,896 Answers
Sounds like you may have a loose or stretched internal wire or possibly loose solder joint. Has the system been updated or upgraded lately?
Posted on Jun 22, 2009
  • Nate Stansfield
    Nate Stansfield Jun 22, 2009
    I do believe it is either an internal system fault and will have to be upgraded, or there is a bad sensor.
I have a Raymarine C80 shart plotter / sounder with a DSM 300. I can't get the "status" light to come on and therefore I can't do a DSM reset. The fuse on the power input to the DSM was blown so I changed...
I would think it's prity much certain that the DSM 300 is duff. I returned mine back to Raymarine for test and repair £200 + VAT They came back unable to repair as they have no parts for the DSM 300 . They undertake to be able to repair units for up to 10 years and I think that's why they offered me a DSM 30 that will work with my analog display in my case a C70 MFDU and the existing transducer. OR an upgrade to a CP370 digital sonar unit, this will work on your existing tranducer but you will have to upgrade your display to a digital unit, I went for the upgrade and purchased an "a"series 9" MFDU with a chart, fantastic performance. This has left me with a spare analog MFDU that will hopefully keep my radar running a little longer before I have to go down that road and upgrade.
Hope this helps
PS there was no extra to pay so a CP370 for £240 was a good deal
Oct 17, 2017 | Raymarine C120 System Pack C120 Raystar...
My marine speed transducer needs to be replaced. I have a Beneteua 351 which is 16 years old. I have cleaned the transducer several times and then reinstalled. It will work for a couple of minutes and then...
Yes. You need to make sure you get the same transducer though. With you system being that old, you may have a transducer that is old where there is not a direct replacement. You need to make sure you get the correct transducer. You may need to get a "flapper" kit to update your housing to the new style.
Jun 15, 2010 | Raymarine St300/P371 Speed Nylon Thru Hull...
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Apr 13, 2010 | Raymarine C80 GPS Receiver
I need a new power cable for a raymarine DS500X fishfinder. Where is a good place to buy?
Contact Raymarine or your nearest Raymarine dealer. Raymarine normally has those things on their website although it's a bit cryptic to find sometimes.
Jan 18, 2010 | Raymarine Ds500x Color Fishfinder: Ds500x...
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
Nov 14, 2009 | Raymarine C80 GPS Receiver
Raymarine ds500x brand new works good but will give false bottom readings occasionally corrects itself fairly quickly 30 seconds to two minutes wondering why it does this and how to correct it
If the transducer is not correctly mounted this may happen due to air, etc. If the unit never gives a depth reading that looks like dashes
( - - ) then there is likely nothing wrong with it aside from the transducer placement.
Aug 06, 2009 | Raymarine Ds500x Color Fishfinder: Ds500x...
My raymarine ds600x is losing bottom at 120 feet...water temperature is at 220. I have a thru hull transducer...Im wondering if my ducer is fouled up with marine growth or is it a bad ducer or head unit.....
The depth loosing bottom would certainly indicate that you may have growth fouling the transducer, however the sea temp 220 degrees indicates possibly a different problem. Start by being sure the transducer is squeaky clean and see what that does for you.
Jul 23, 2009 | Raymarine Ds600x Fishfinder Display Only
No fixed postion has ? over gps icon in upper right corner of unit
touch lower right hand corner and see if it reboots software. will probably lose all info saved
May 30, 2009 | Raymarine C80 GPS Receiver
Depth sounder
the transducer has to be in the water or attached to the inside of the hull if fiberglass with no air between the hull and the transducer. It doesn't transmit thru air.
Mar 12, 2009 | Raymarine Boating
Scanner self test result...is display comms/fail /raymarine c80 18" dome
Chances are that your scanner cable may be bad. Check inside the dome and make sure that the little wires going into the black connector from the radar cable are seated correctly and all the way in. This can cause tons of problems. Also check to make sure that your pins in the back of you unit are not corroded or broken off.
Jul 24, 2008 | Raymarine C80 GPS Receiver
GPS Logo
70 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
