Question about Landice L7 LTd Pro Sports Trainer Treadmill
Tengo un landice L7 la falla esta que cuando la pongo a funcionar libre,la cinta alcansa la misma velocidad que indica la pantalla pero cuando la pongo a funcionar y me coloco sobre la cinta ciento como si el motor perdiera potencia y al pulzar el boton de aumento de velocidad el indicador va marcando el aumento pero el motor se queda en la misma velocidad , al sustituir la targeta de control por la de una maquina identica el problema desaparese .Ahora bien dada la rextriccion de dolares en venezuela me veo en la nesecidad de tratar de reparar la targeta de contol por lo tanto necesito vuestra ayuda para que me indiquen a travez de vuestro departamento electronico cual componente de la targeta de control esta fallando para asi poder solucionar la falla . Les recuerdo que todas mis cintas son landice , muchisimas gracias
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Posted on Feb 28, 2010
  • 20 Answers
SOURCE: Motor or belt sqeals -
this may require proper troubleshooting but it is either the belts on the motor needs changing or the track belt ihas come to the end of it's usage life... but check thorougly.
Posted on Apr 09, 2011
Tengo una Toshiba Satellite A 305 S 6825. Mi problema es cuando le conecto el AC esta se apaga y enciende nuevamente indicando error. Si cargo la bateria completamente y la desconecto del AC esta funciona...
Ya que usted informa que con la batería sola funciona, pues es de pensar que el cable electrico y el cargador están defectuosos.Compre o pida a un amigo un cable compatible con su LTop y haga una prueba.Si funciona el cable esta dañado.Si no funciona entonces el socket de entrada de el cable esta defectuoso.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Computers & Internet
Tengo una Nikon Coolpix L4 y cuando la pongo a funcionar el menu y todo esta en Ingles, lo reseto y lo pongo en español pero al apagar la maquina y volverla a encender tengo de nuevo el menu en...
si, la bateria interna de la c?mara esta agotada , por eso no puede mantener los ajustes permanentemente. tienes que mandar a reemplazar la bater?a interna .es como la de un reloj de mano .
Oct 31, 2017 | Nikon Coolpix L1 Digital Camera
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
Tengo un problema con mi lavadora whirlpool duet cuando la enciendo para lavar me presenta un fallo en la pantalla. y sale fallo 22.que es el swich de la tapa.pero se lo cambie por uno nuebo y sigue...
ke tal tengo una lavadora whilpool duet pero al encenderla y poner el ciclo de lavado normal me prtecenta una falla dice falla 11 y no se que es esta falla me podria orientar?
elrayo_0609@hotmail.com gracias
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hola mi nombre es christian, yo tengo un pioneer DEH-P7900BT y cuando lo conecto solo prende las luces de los botones pero la pantalla no, no se si esta mal conectado o el stereo no cirva. por favor...
Esto no es una solucion, pero la misma cosa esta pasando a mi. Estava trabajando, pero en un momentito se cebro.
pienso que tu radio no cirva. La misma cosa esta pasando a otros dos personas en estos forums.
my espanol es muy mal.
Dec 08, 2009 | Pioneer DEH-P7900BT CD Player
Velocidad de PROCESADOR PENTIUM III
Si se trata de un portátil es que revela la actual velocidad del procesador cuando se ralentiza. Cuando no usas un pleno potencial transformador la computadora portátil que frena a salvar la vida de la batería.
Jun 22, 2008 | Intel Pentium III, 866MHz Pentium III-M...
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Landice L7 LTd Pro Sports Trainer Treadmill Logo
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Sportsmith LLC
Sportsmith LLC
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
