Question about Clothing Accessories
What shape rhombus - Clothing Accessories
What would the area of the rhombus be
I don't think you can figure out the area of this rhombus/parallelogram.
The area of a parallelogram is base, which we have, times height.
Picture the parallelogram with all the angles being 90 degrees. The area would be 54 square centimetres. Now imagine you can slide the top part of the parallelogram to the right, with the bottom fixed and all the corners on hinges. In theory, you can nearly slide the top down until it is just above the base. The area would approach zero, as the height of the parallelogram decreases.
Good luck,
Paul
Apr 14, 2016 | Office Equipment & Supplies
The diagonal of rhombus are 8 cm and 6 cm then the length of each side of the rhombus
https://www.mathsisfun.com/geometry/rhombus.html
Lesson HOW TO solve problems on the rhombus sides and ...
www.algebra.com > Geometry > Customizable Word Problem Solvers
  1. Cached
Lesson HOW TO solve problems on the rhombus sides and diagonals measures - Examples ... Find the perimeter of the rhombus, if its side is 7 cm long. ... Since all four sides of the rhombus have the same length, the measure of the side ... 32/4 cm = 8 cm. ... In our case the legs are 12/2 cm = 6 cm and 16/2 cm = 8 cm long.
SOLUTION: The diagonals of a rhombus are 6 cm and 8 cm ...
  1. Cached
  2. Similar
SOLUTION: The diagonals of a rhombus are 6 cm and 8 cm. What is the ... (paid link). Click here to see ALL problems on Geometry Word Problems ... We need to find the side of the rhombus using the Pythagorean Theorem. After that, we use ...
The diagonals of a rhombus are of lengths 6 cm and 8 cm. Find the ...
https://in.answers.yahoo.com/question/index?qid...
  1. Cached
  2. Similar
Jun 29, 2013 - The diagonals of a rhombus are of lengths 6 cm and 8 cm. ... rough aketch and you will see that in each triangle the shorter sides are 3 cm and 4 cm, so using the Theorem of Pythagoras, if we call the hypotenuse l cm, then l^2 ... Rhombus
Mar 30, 2016 | Office Equipment & Supplies
What shape has 4 sides
Quadrilaterals, including squares, rhombuses, and trapezoids.
Mar 18, 2014 | Computers & Internet
Millimeters in a centimeter
2 centimetres and 2.5 centimetres.
There are ten (10) millimetres in a centimetre.
Feb 17, 2014 | Computers & Internet
A parallelogram with 4 equal sides
A rhombus (and in a special case, a square).
Dec 16, 2013 | Office Equipment & Supplies
Need to download rhombus rh1200 scanner driver
need driver for RHOMBUS RH-1200 US 600DPI USB SCANNER
May 21, 2011 | Computers & Internet
Can't seem to locate the pcv on friends 99 gtp supercharged anybody know where it is located?
It is located behind the supercharger rotor housing on the drivers' side, almost straight across from the intake plenum. It is mounted beneath a rhombus shaped plate with 2 1/4" bolts. The valve is mounted on top of a spring and there is a gasket on the bottom of the plate so be careful not to break it...it's not rubber. The plate holding it down also bolts into aluminum so don't over tighten.
Jun 12, 2009 | 1999 Pontiac Grand Prix
HC 1500 skewed image issue
Hi there
I've worked on a few Mitsubishi's in my lifetime and one of their most common problems is the DMD Board that goes faulty and this makes the image go all pear shaped.
If you've only had the unit for 3 months now it should still be under warranty and the warranty covers these kind of repairs.
Hope this helps you !
Mar 26, 2008 | Mitsubishi HC100U Multimedia Projector
Clothing Accessories Logo
35 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
