Question about Bell & Howell Sidekick 1400 Path-Through Scanner
Get paper path error when path is clear & clean.
Continue to get intermittent error saying paper still remains in the scanner. No obstructions present; have cleaned the senors & rollers repeatedly. Occassional success but error reoccurs.
Any suggestions?
  • 490 Answers
There are two types of sensors, optical and mechanical. Sometimes the mechanical sensor get stuck and give a message to the scanner that paper still remains inside the scanner. Check if any of them is stuck, Blow air from a dsiatance so that any shreds of paper is foreced out.
S. Mohan, India
Posted on Jun 23, 2009
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Feb 13, 2014 | Epson Artisan 835 Wireless All-in-One...
Canon DR9080c - getting error code P00 which means paper jam in the scanner but there is no paper in there & I have cleaned all the sensors! What else could this be?
This is a common problem in 9080C. When the top cover is closed, the sensor sends light and it is reflected thro the black cover in the bottom. Then the scanner assumes the cover is closed. Any obstruction is treated as P00 error. You will notice three small oval & round shaped clear plastic. Clean them with a brush and ensure the edges are clean. Light goes thru one side and come thro the other, which is sensed by the unit placed in the top cover.
S. Mohan, India
Sep 12, 2013 | Canon DR-9080C Path-Through Scanner
HP Laserjet M2727nf 's scanner
If the problem is ALWAYS, can be caused by an error in the configuration of the white paper size. That is, the printer has a conflict of comparing the original document size and the size of the white paper.
If the paper has left marks from objects obstructing the paper path. This alone can resolve the paper feeding disarm until you check that the sensors are free of obstructions.
You can also clean and well make sure they are free of any problems and ensure that the paper path goes smoothly.
Try also check the good condition of the rubber paper feed, paper separation and drag.
Feb 08, 2012 | HP Laserjet M2727nf Multifunction Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
During startup the drive belt slips and gives an error
Open the printer's door and look for the print carriage. It's the platform that moves back and forth over the paper, probably where you put new cartridges. Unplug the printer, and check this belt and its pulleys to see if it's either broken or possibly covered in ink. The drive belt will be black and have gear teeth on it. If you see a metal or plastic ribbon, that's more likely the encoder that let's the printer's computer read the position of the carriage. See if you can nudge the carriage and make it move a little; it may simply be jammed. Check the carriage's moving path and make sure it's not obstructed. Any other problems would probably best be handled by Epson.
Feb 27, 2010 | Epson Stylus R380 InkJet Photo Printer
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
S. Mohan, Chennai, India
Apr 16, 2009 | Canon DR-5010C Scanner
Canon DR-3080cii paperjam
The 3 paper sensors are located along the center of the paper path. They are: Registration (lever type) on the bottom between separation & registration. Look for lever damage or torn paper. Scan Start (reflective) on the top between registration & front reading roller. Clean the sensor window with qtip & alcohol. Delivery (lever) at the eject roller. Same as reg, but harder to see due to location.The feed roller exchange kit is 6915A001. The rollers in this machine are not considered user replaceable.
Oct 09, 2008 | Canon DR-3080CII Path-Through Flatbed...
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Bell & Howell Sidekick 1400 Path-Through Scanner Logo
256 people viewed this question
Top Bell & Howell Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Bell & Howell Office Equipment and Supply Expert? Answer questions, earn points and help others
