Question about Canon iP100 Portable Printer
Canon ip100 missing colors
Ran nozzle check, cleaning, and printhead cleaning, still missing colors
  • 18 Answers
SOURCE: Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
Posted on May 02, 2009
  • 413 Answers
SOURCE: nozzle check has even missing bands of color on new printhead
You will have to do an external clean of the print head.
Remove the cartridges.
Remove the print head from the printer.
Be careful not to touch the metal contacts on the head.
Boil some water, pour 1/4" (6 millimetres) of water into a saucer.
Immediately place the part of the print head 'where the ink comes out' in the water.
Leave in there for 2 minutes.
This will clean any junk out of the holes.
Place the head on some tissue paper and let the paper absorb the water.
Do not rub the print head with the tissues!
Replace the print head back in the printer, replace cartridges and run the setup - alignment.
This works most times unless the print head is faulty...
Posted on Jun 18, 2009
komguy
  • 2306 Answers
SOURCE: Canon i990 printhead
Nothing cleans these printheads well, the best is to replace the printhead, QY6-0055-000, around $70.00
Posted on Jul 03, 2009
  • 73 Answers
SOURCE: Canon IP 90 clogged printhead nozzles. How to remove printhead?
To avoid drying of the Print Head and clogging of the nozzles, note the following.
*When you turn off the Machine
Follow the procedure below to turn off the machine.
1)Press the ON/OFF button to turn off the machine,
2) Confirm that the POWER lamp has gone out.
This takes a few seconds or as long as 20 seconds.
3) Unplug the power cord from the wall outlet.
If you are using a power outlet strip, you can switch off instead.
When you press the ON/OFF button to turn off the machine, the machine automatically puts a protective cap on the Print Head to prevent the ink from drying. If you remove the power cord or switch off the power outlet strip before the POWER lamp goes out, this capping will not be done properly, causing the Print Head to dry and clog.
* When You are not Using the Machine for a Long Time.
When you are not using the machine for a long time, print or copy in both black and white and in color or pertorm Print Head Cleaning, about once a month to prevent degradation of the Print Head.
Numerous nozzles are installed in the Print Head for high -precision printing. Just as the uncapped tip of a ballpoint pen or marker becomes dry and unusable if it is not used for a long period of time, the print nozzles becomes blocked by dried ink. Periodically printing or cleaning of the Print Head can prevent this blockage.
Note :
*If the printed area is traced with a highlight pen or paint-stick or stained with water or sweat, ink may blur depending in the paper.
*If the print head nozzles get clogged , printouts will become faint or particular colors will not be printed properly.
When Printing Becomes Faint or Colors are Incorrect.
When printing becomes faint or colors are incorrect even if the ink remains in the ink tanks, the print head nozzles are probably clogged. Print the nozzle check pattern to confirm the condition of the nozzles and then perform the Print Head Cleaning.
Note : Before performing maintenace
*Open the Scanning Unit (Printer Cover) and make sure that all lamps for the ink tanks are lit red.
-If any one of the lamps is flashing slowly, the associated ink tank is running low. You can continue printing for a while, but we recommend you to have replacement ink tank available.
-If any one of the lamps is flashing fast, the associated ink tank is emty. Replace the ink tank.
If an ink tank is flashing fast even though ink remains in that ink tank, it is inserted into the wrong position. Make sure that the ink tank of the correct coloris inserted in each position matching the label.
-If the ink lamp is not lit, the tank is not set properly. Press the <PUSH> mark on the ink tank until the tank clicks into place. Make sure that all the packaging material is peeled off the ink tank.
*Increase the print quality setting in the printer settings.
Step 1 : Printing the Nozzle Check Printer.
1) Make sure that the machine is turned on, open the Front Feed and extend the Output Paper support.
2)Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder.
Set the Paper Thickness Lever to the left.
3) Press the Paper Feed Switch to select the paper source where you have loaded paper.
4)Print the nozzle check pattern.
a) Press the Menu button.
b) Use the right and left arrow buttons to select the Maintenance/settings, then press the OK button.
The maintenance /setting screen is displayed.
3) Use the right and left arrow buttons to select Maintenance, then press the OK button.
The Maintenance screen is displayed.
4) Use the Up and Down arrow buttons to select the Nozzle check and then press the OK button.
The pattern confirmation screen is displayed.
5) Use the Up and Down arrow buttons to select Yes and the press the OK button.
The nozzle check print is printed, and the pattern confirmation screens are displayed alternately.
Examine the pattern and take the appropriate action.
Step 2: Print Head Cleaning
Clean the Print Head if lines are missing or if white streaks appear in the printed nozzle check pattern. Cleaning unclogs the nozzles and restores the print head condition. Note that cleaning the Print Head causes used inl to be absorbed in the ink absorber. Cleaning the Print Head consumes ink, so perform Print Head Cleaning only when necessary.
1) Make sure that the machine is on, open the Fron Feeder, and extend the Output Paper Support.
2) Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder/
4) Start Print Head Cleaning.
b) Use the right and left arrow button to select Maintenance/settings, then press the OK button.
c) Use the right and left arrow buttons to select Maintenance, then press the OK button.
d) Use the Up and Down arrow buttons to select Cleaning and then press the OK button.
The confirmation screen is displayed.
e) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Print Head Cleaning starts.
Do not perform any other operations until Print Head cleaning finishes. This takes about 50 seconds.
The pattern print confirmation screen is displayed.
f) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Note : If the problem is not resolved after performing steps 4 and 5 twice, try Print Head Deep Cleaning.
If print quality does not improve by standard Print head Cleaning, try the Print Head Deep Cleaning, which is more powerful process. Note that cleaning the Print Head causes used ink to be absorbed in the ink absorber. Print Head deep Cleaning consumer more ink than the standard Print Head Cleaning, so perform this procedure only when neccessary.
1)
d) Use the Up and Down arrow buttons to select Deep Cleaning and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep cleaning finishes. This takes about 100 seconds.
5) Check the condition of the Print Head.
a) Print the nozzle check pattern to check the print head condition.
If a particular color is not printed properly, replace the ink tank of that color.
b) If the print head nozzles are still not cleaned, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
c) If this does not solve the problem, the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Posted on Nov 30, 2009
pineworks
  • 4041 Answers
SOURCE: prints but no color will come thru Checked nozzle
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Hi my plotter always print a blue color on all pages.for each kind i print i have it has no differences.does any one knows about my problem? my plotter model is Canon W7200 thanks best regards
Try printing the Nozzle Check pattern. Check if colors are printed correctly. If not, try Printhead Cleaning A first then check again the Nozzle Pattern. If there's a small changes to the pattern, try Printhead Cleaning B. If problem persist, try changing the Printhead.
Oct 09, 2014 | Canon imagePROGRAF W7200 InkJet Printer
Will not print in red
Aftermarket cartridges are easily the number one service issue in my shop. You have clogged the printhead. If you run `cleaning, color' (deep cleaning is NOT recommended), then the `nozzle check' to see results, you should see improvement with each color. If you don't, stop and take your unit in for service. It may need a new printhead.
Apr 02, 2014 | Canon MX882 All-In-One InkJet Printer
How do i remove and clean the printhead from a canon pixma mp780?
Hi there. i understand that you want to clean the printhead of your canon pixma mp780, dont worry im here to help you out with this.
do this following steps in order for you to clean the printhead.If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Take Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary ok?
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
hope that this steps helped you a lot in cleaning the printhead of your printer.Good Luck!
May 30, 2011 | Office Equipment & Supplies
Black ink does not print. Color works fine.
The print head is probably blocked then. You may be able to get a cleaning cartrige if you look online. Failing that, it will probably need a service.
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon S900 Now prints murky and dull
Printing is Blurred/Colors are Wrong
? If a specific color does not print, check whether the corresponding ink tank is
empty. Replace if necessary.
? Print the nozzle check pattern to ensure that ink is ejected correctly.
If the nozzle check pattern does not print correctly, clean the printhead.
? Printing the Nozzle Check Pattern
? Printhead Cleaning
If the problem is not resolved after cleaning the printhead several times, the printhead
may be worn out. Contact the Customer Care Center.
Note ? Always ensure that you dispose of the protective cap and protective tape
from a printhead.
? Ensure that you are printing on the correct side of the media.
You can only print on one side of certain media.
Nov 16, 2009 | Canon S900 InkJet Printer
Prints green instead of black. test page is missing magenta color
Sounds like you have a blocked jet. If you have a look in the printer drivers there is normally a option to clean printhead, I would run this through a few times to try and clear the jet.
Nov 13, 2009 | Canon iP100 Portable Printer
Nozzle check has even missing bands of color on new printhead
Jun 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
On the front of the (printhead)cover is a "hole", with that you can lift the cover .
The printhead will move to the center and you can change a cartridge.
To change the printhead if necessary you can squeez the little gray handles next to the cartridges ( one left of the CLI-36 and one right of the PGI-35) , lift the printhead handle and the printhead can be changed.
Nov 24, 2008 | Canon iP100 Portable Printer
Canon S600 bubblejet priner won't print color
In all likelihood, the nozzles in the printhead are blocked. The printhead is the carrier that holds the tanks. Remove the printhead and remove the tanks from the printhead. Flush the printhead THOROUGHLY with hot running water. You can also **** on the color discharge area (square and the black discharge area (rectangular) on the bottom to draw warm watr through the nozzles to further clean them. Dry the prinhead thoroughly, reinsert your tanks and reinsert the printhead in the printer. I then do a "nozzle check" to refill the passages in the printhead and get things flowing agan.
Oct 25, 2008 | Canon BJC S600 InkJet Printer
Canon iP100 Portable Printer  Logo
74 people viewed this question
old marine
old marine
