Question about Arctic Cat 2012 T 570
Has trouble shifting into reverse - Arctic Cat 2012 T 570
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 220 Answers
LInkage may be out of adjustment. To check,put in forward position,loosen shifting rod jamb nuts then turn the rod until you have just a touch of play. This will allow the reverse to be completely ingaged when shifted.
Posted on Feb 02, 2015
Trouble shifting into 2nd gear and reverse but drives good once it shifts?
No not the whole transmission. Could be a band or servo. It still has to come out and be tore down to fix.
Nov 22, 2015 | 1996 Ford Explorer
Why would my '02 Olds Alero suddenly not shift into reverse?
My guess is the ignition needs to be replaced. check to see if theres a recall for it. 2 years ago on my 2002 alero I found a recall for the flasher switch which was causing intermediate directionals and 2 more for the computer
Jun 30, 2014 | 2002 Oldsmobile Alero
My 96 Buick Century (automatic transmission) has trouble shifting in reverse (I have to shift back and forth for about fifteen minutes until it will go in reverse). It also has trouble shifting into drive...
Transmission filter may be plugged. If it is, that indicates wear parts are worn out. Transmission needs to be rebuilt. The transmission control module can cause the problem as well as shift solenoids inside the transmission. No simple fix. You'll have to go inside.
Apr 15, 2017 | Cars & Trucks
1998 VW Beetle 5-speed trouble getting it in to reverse
I have a 1998 VW Beetle and when I first bought it, (used) shifting into first was the same action for shifting into reverse. They were so close I usually went into first when trying for reverse. I took it to a transmission shop and they replaced part of the shift linkage that is famous for wearing. It cost me maybe $60.00. Now she shifts like a new car.
Jan 24, 2011 | 1998 Volkswagen Beetle
When I try to shift from park to drive it gets tight at reverse as if doesn't want go but once out of reverse it shift normally until shifting back to park when I have to go threw reverse then it tightens...
Is it only when you go from park to reverse? Or is it just as bad going from neutral to reverse? I've noticed on mine that it's often tight if I park on even a slight slope. If it only happens when going from park to reverse, try this. Hold your foot on the brake, and put the car in drive. Keeping constant pressure on the brake, go back to park, then back into drive. Did you feel the stiffness when you had your foot on the brake?
Oct 18, 2010 | 2004 Pontiac Grand Prix
Nedd to see the manaul transmission gear shift
"The shift pattern is a little different, with reverse starting to the left of first, in the German (Getrag in this case) pattern rather than the "reverse-in-sixth" Japanese pattern. It's nearly always easy to find the right gear, though sometimes reverse can be tricky (presumably this gets easier with time)." moz-screenshot.png from a review I found , hope it helps. I suspect reverse is up and to the far left R 1 3
I__I__I
I I
2 4
Mar 25, 2010 | 2005 Chrysler PT Cruiser
Trouble shifting into 1st and reverse
If you have a fluid clutch then try bleeding to see if any air is in the pipes.If its cable check the adjustment.If all is fine then you have a clutch pressure plate fault.Solution Replace the clutch assemebly
Nov 17, 2009 | 2001 Mitsubishi Eclipse
My 2000 4 runner won't shift into park
sounds like a faulty selector cable/rod as park and reverse are next to each otheron selection, it may just require lubricating.
Feb 02, 2009 | 2008 Toyota 4Runner
Shift problems in 95 chrysler concorde transmission
Sorry but if your reverse is having trouble you will probably have to replace or rebuild tranny like me. Otherwise try new filter and fluid first.
Nov 09, 2008 | 1995 Chrysler Concorde
Automatic Tranmission forward gear works reverse doesn't
YOU HAVE A SHIFT SOLENOID THAT HAS EITHER FAILED OR IS STUCK, DO YOU HAVE ANY TRANS TROUBLE CODES?
Nov 02, 2008 | 1990 Chevrolet S-10 Blazer
Arctic Cat 2012 T 570 Logo
317 people viewed this question
Top Arctic Cat Winter Sports Experts
ray gallant
 steve
steve
rhodesworks
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
