Question about Samsung Televison & Video
How do you hard reset a samsung security system sme-2220n?
Forgot password and need to reboot
  • 4 Answers
SOURCE: how do I reset a SMT-190DN samsung security system
Just talked to Samsung regarding Reset procedure. Simple: Press CH2 and Alarm buttons on receiver at same time for 10 seconds. It will reset to factory.
Posted on Nov 18, 2009
SOURCE: forgot password to my samsung sgh-a887
Just input the following: *2767*3855#
Posted on Dec 13, 2009
js123india
SOURCE: reset security password for samsung s3650 corby
Master Reset code
*2767*3855#
Posted on Mar 21, 2010
SOURCE: how to reset my Samsung Eternity SGH-A867
Master-Reset: all personal data will be deleted *2767*3855#
Posted on Apr 07, 2010
lock123
  • 6831 Answers
SOURCE: forgot the security password to my samsung strive
Hello
Ok, if you are talking about the phone security code which was usually asked when the phone has been restarted, here is how we fix this.
You will need to enter in the wrong code until you are prompted to enter the PUK code. Click HERE to read how retrieve the PUK code.
Let me know if i understood the question.
Kind regards
Andrea
Posted on Sep 03, 2010
Hi Hi i forgot the password to my samsung galaxy note 10.1 2014 eddition
No problem follow the steps bellow to factory restore you Galaxy note 10.1
- Turn Off your Samsung Galaxy Note 10.1 device.
- Wait for 10 seconds, Then move to the next step.
- Press and hold Volume Up key + Power key.
- Keep pressing the above keys until the Samsung Logo appears,Then release Power key only.
- When you see Factory reset / System Recovery menu on screen release the Volume Up Key.
- Use Volume Down key to select Wipe Data / Factory Reset option.
- Use Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
Notice: The Hard Reset / Factory Reset operation will delete anything that are saved in your phone's internal memory, So make a backup of your data in case you can access them.
Feb 05, 2018 | Samsung Cell Phones
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
How do I unlock my galaxy j3 forgotten my password
Pompeo, You may have to do a hard/factory reset to get it up and running. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
FAQ SAMSUNG J320P Galaxy J3 2016
How to Hard Reset Remove Password Samsung Galaxy Core Prime
How to reset your android if you forgot your password and google account
Galaxy J3 What do do if Forget my Screen Lock Password on my Samsung...
Jul 02, 2016 | Cell Phones
What's your question?I FORGOT THE PASSWORD OF MY SAMSUNG GT-S7500 HOW DO I HARD RESET IT?
1.Turn off your phone 2.Press together volume up + volume down + home button + power button until Samsung logo appears on screen 3.Browse with volume buttons and select "wipe data/factory reset" then press home button 4.Choose "yes" with volume buttons and press home button to select it 5.Wait until format is complete 6.Select "reboot system now"
Mar 29, 2015 | Samsung Cell Phones
Samsung forgot phone pattern
You can remove your lock by a hard reset. This procedure will erase your personal data like accounts, other passwords and etc.
- Switch off the tablet. (To force shut down, pres and hold the Power button more time).
- Press and hold the Power and the Volume Up keys.
- When you see the Samsung logo, release only the Power key.
- Use the Volume Up/Down keys for scrolling and the Power key for OK.
reboot system now.
This procedure is same for Galaxy Tab 2.
Aug 06, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
System keeps rebooting
Check the plug that goes into the monitor for secure connections. Check Samsung for any firmware updates. Pay attention to how many beeps before shutdown, this could be a code to the problem. Samsung does have a help line to call look in manual. Not really familiar with security systems. If a computer was acting this way I would say it is possible the hard drive is bad. http://www.samsungsv.com/Support/ContactUs
Mar 17, 2014 | Samsung 8ch Security System Sme-2220...
My phone is locked, saying enter google account info but nothing works, also cant remember pattern either
Best Solution;
1. Power off phone
2. Press and hold Home Button ( middle ) + Volume Up + power on button
3. Wait for 5 second until Android System Recovery menu appear
4. There are 4 options
reboot system now
apply update from sdcar
wipe cache partition
5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
6. After the process done, phone will reboot.
Sep 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
Password locked j700 samsung phone
To reset the security password of your j700,type this code *2767*3855# to
set the default security password into 00000000.Just wait until rebooting completely done.make sure you have at least full battery..
Jan 13, 2010 | Samsung J700 Cellular Phone
Televison & Video Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
