Question about Baseball & Softball
Bushnell hybrid files corrupted - Baseball & Softball
How do i know if my bushnell 119438 Nature View Hybrid Trail Camera is faulty?
Why do you think it has a problem? Your video appears to be working. It is bright, due to IR reflection, but the animals can be seen and the picture seems to be in focus.
Have you checked the user manual instructions for setting it up correctly? From the manual recommendations, the camera in this instance may be set too close (page 27). If you need a copy of the manual, you can download it from here: http://www.manualslib.com/download/717012/Bushnell-119438.html
Apr 22, 2015 | Bushnell Cameras
Bushnell hybrid won't charge
Most likely a dead battery. Easily replaceable at home. The factory won't tell you that.
Dec 01, 2012 | Bushnell Hybrid Pinseeker Laser...
Laser repair bushnell hybrid GPS
laser has stopped working,gps is not accurate
Jun 13, 2012 | Bushnell Hybrid Pinseeker Laser...
I have a Bushnell yardage pro XG. I had installed the sync software and it was working fine. Then all of a sudden it would not load with the browser or i would get a message that the application was...
Look for a file under the native folder, that has an extension of .lck
Should be located in this location or close to this, C:\Program Files\Bushnell\Yardage Pro\Native ...
When found, delete the LCK file.
The 99% problem is a TEMP variable problem generally, go HERE for that solution.
To get to the Bushnell downloads, go HERE
Also ... JAVA 7 will break things. Uninstall it, and install 6.33 by going here.
Happy golfing :)
Aug 16, 2011 | Bushnell Yardage Pro 368100 Handheld GPS...
I was just given a bushnell 675x5 from a friend, but he had never used it and didnt have instructions. where could i get a users manual? also it has a couple damaged parts i will order if you could tell...
All of Bushnell's manuals are on this web site-- find your telescope and download a free copy-
http://www.opticsplanet.net/bushnell-warranty.html
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Jul 31, 2011 | Bushnell 675x5 EQ Reflector Telescope
I have a bushnell northstar 78-8831 and need to know how to reset the telescope. when in align earth mode it asks me to align star 2, skipping over star 1.
This scope has many goto issues. For one there is no way to reset the controller or to reload the firmware inside the hand controller. The firmware is probably corrupted.
You can contact their repair and support web site here:
Aug 10, 2010 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Trail Scout corrupting SD Card
camera has a 2 year warrenty, this is a manufacturing problem, sent mine in and they are sending me a new unit to replace the old one.
Sep 24, 2008 | Bushnell Trail Scout 11-9500c Digital...
Driver installation
computer responds with error cant find file
Dec 22, 2007 | Bushnell ImageView 11-8200 Binocular
Hitachi hardisk
there is a problem in your operating system, if you are using winxp, try to run this by clicking the repair option in this way this will replace the corrupted files of o.s.
Oct 29, 2007 | Hitachi DVD/HDD HYBRID 30GB 2.7 WS LCD...
Baseball & Softball Logo
483 people viewed this question
Top Baseball & Softball Experts
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Are you a Baseball and Softball Expert? Answer questions, earn points and help others
