Question about Whirlpool ED5SHAXM Side by Side Refrigerator
My fridge keeps trip the electrical panel
My fridge came on once when we first brought it back home. Now, it does not come on. It keeps tripping the electrical panel.
  • 72 Answers
Have a company come out to service it if it is under warranty. First make sure that it is not a weak breaker, plug it into an outlet on another circuit.
Posted on Jun 22, 2009
Fridge keeps tripping the house surge protector switch what would cause this temp curcuit board has been replaced but it still trips the switch
there is a problem in the wiring insulation of the fridge or moisture in an electrical control of the fridge
get an electrician in to check it out
Feb 17, 2016 | Refrigerators
My fridge keeps tripping the power
Your solution is one of two things.
First is the circuit you have plugged the refrigerator is either over its limit and the breaker is tripping because it is overloaded. In this case you will have to determine what load also share this circuit and eliminate the extra loads or move the cord to another circuit which is not overloaded. Most home circuit are wired with 14 gauge and is rated at 15 amps. When the circuit gets to 15 amp and more, the associated breaker trips to prevent overload.
Second, Your refrigerator may have a short and needs troubleshooting to find the cause. To see if it is a bad circuit try plugging into a circuit via extension cord to circuit in another room receptical. The reason I say another room, when electrical installers wire circuits, you can put several recepticles on the same circuit. If you plug your refrigerator in the same circuit you had it on before then you will get the same problem, your refrigerator tripping again. If your frig trips on a different circuit then troubleshooting the cause will normally require a tech.
Good luck and hope this helps.
Oct 28, 2014 | Refrigerators
Refrigerator disables all outlets on its circuit but the 1st outlet
I just answered your question on the previous situation but here it is again. A GFCI receptacle placed in a circuit controls power to all remaining devices on that circuit. If the GFCI trips, anything after it shuts down. That is your situation. If your fridge keeps tripping the GFCI, it has a grounding problem. You should have your fridge checked out so that your family does not receive an electrical shock when contacting the fridge. Be safe.
Aug 31, 2014 | Electrical Supplies
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
Fridge tripping electric
it might still have a warranty so you might be able to return it or get it repaired
Jun 11, 2012 | Refrigerators
Hi, my fridge freezer keeps making the electric trip out. help!!!
Try this:
Turn your thermostat as warm as it will go, you are trying to isolate the compressor and keep it from turning on. If your fridge has an "off" position, then turn it off. Reset breaker, plug refrigerator back into the outlet. If the fridge trips while "off", then you are likely looking at a damaged cord / wiring.
If the breaker doesn't trip, unplug the fridge, and move the thermostat to the warmest position possible. Plug fridge back in, If the breaker holds, then you are on right track. Slowly move the thermostat to a cooler setting. You want to just reach the point where the compressor tries to start. If breaker holds here, then you are in good shape so far. It indicates a problem with the defrost heater (if equipped), or the ice maker (if equipped). If the breaker trips as soon as the compressor tries to start, your compressor may be damaged (bad and expensive).
Aug 17, 2010 | Refrigerators
The main rcd keeps tripping off round about the same time everyday
do you have a fridge with a defrosting cycle? quite often when a fridge goes into defrosting mode it can dump some voltage to earth which trips the RCD. The other possibility is an electric pump turning on doing the same thing. or it could be a trouble with your power source. if you give me more information i could possibly help you more.
Oct 27, 2009 | Electrical Supplies
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
THE MAYTAG fRIDGE/fREEZER BLOWS OFF I.E. IT SWITCES ITSELF OFF AND THE MAIN FUSE TRIPS OFF. THE PLUG FUSE NEVER BLOW OFF THOUGH.AFTER COUPLE OF DAYS,WHEN WE PLUG IN THE THE FRIDGE/FREEZER IT WORKS FINE AND...
what's the model number,i don't understand what you're asking,are you saying the fuse keeps popping in the house fuse panel?or the fridge stops running and the house fuse is ok.what is i.e.
Feb 07, 2018 | Maytag Refrigerators
Whirlpool ED5SHAXM Side by Side Refrigerator Logo
256 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
