Question about Dymo DateMark Date/Time Stamper
Where can I find a belt replacement for my datemark dymo time stamp?
SOURCE: Dymo DateMark stamper doesn't print.
if it is an older model [2001 or so] you just gently put your hand over the top like your going to pick it up but just push down and slightly forward. there is a button on the underside.
Posted on Mar 06, 2008
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
SOURCE: dymo datemark
open the back cover where the batteries are and press the pinter reset button
Posted on Nov 05, 2008
SOURCE: Dymo stamps doesn't see USB Dymo scale
I connected my 10lb USB scale directly to the PC port bypassing a hub.
it worked fine!
Posted on Apr 21, 2009
komguy
  • 2306 Answers
SOURCE: How do I reink the Dymo DateMark Stamp
You have to remove the ink roll door, on the front left near the bottom. Pull the roller out with a tweezers, add a few drops of ink to the roll and re-install. No matter how careful you are, you will get some ink on your hands...
Posted on Jun 22, 2009
My dymo datemark stamp says "reset" but we have no idea how to do it?
Take off the back cover and insert the tip of a pen or paper clip in the little button between the 3.0 volt battery door and the AA batteries. It is "printer reset" around the little hole. This should work. It works unless something is wrong with the ribbon of letters that can get stuck. I'm trying right now to get my to reset using this solution (that has worked previously) but it is not. So it is a **** shoot!
Jan 28, 2010 | Dymo DateMark Date/Time Stamper
How quickly do the AA batteries run down in the DYMO Datemark. I just started using a new one this morning and have stamped maybe 50 times and have now received the flashing p.reset
Mine usually last at least 6 months. But I am careful to lean it back slightly to make sure It's not touching the switch on the bottom, and I only use fresh energizer batteries.
Jul 02, 2009 | Dymo DateMark Date/Time Stamper
Jun 22, 2009 | Dymo DateMark Date/Time Stamper
Dat stamp not stamping
I had the exact same problem. I took the back off of the stamper and like some others, I pushed the reset button with a pen. Surprise it worked!!! I am now able to date stamp my "stuff".
Hope this helps somebody.
Donna
Jan 19, 2009 | Dymo DateMark Date/Time Stamper
You might try connecting the USB cable directly to one of the computer's USB ports.  My scale (DigiWeigh) showed as not connected when it was connected to a USB hub.  When it is connected directly to the computer, it shows the scale as connected.  Unfortunately, it still won't transfer weights to the Dymo Stamps software.
Dec 11, 2008 | Dymo DateMark Date/Time Stamper
Jan 25, 2008 | Dymo DateMark Date/Time Stamper
95 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
