Question about Canon Lc-e10 Battery Charger For Lp-e10 Battery Pack - Eos Rebel T3 Camera
Why does my canon lc-e10 battery charger flash?
Canon 6D battery charger flashing
Even if you won't or can't believe this, your battery can be completely dead. Or just one cell does not work anymore, but that with the same result.
When the charger is flashing it is saying I'm charging. It starts with slow flashing (once a second) then when about half charged twice a second and above 75 % three times a second. The blinking will be with orange. And after the battery is charged, the LED will turn green. Could be the battery has a bad contact or the charger.
But if al the contacts are clean and shiny the charger should start charging directly. Never leave the battery blinking for such a long time. Normal charging of a complete discharged battery can be done within 3 hours. (at room temperature)
To make sure the battery is not ok, use a multi meter and check the voltage. When measuring the voltage it should be above the working voltage that is printed on the battery. Although Canon does not print the voltage in its manual, I think he voltage will be around 7 V. Read the battery and if the voltage is only one tenth of a volt below what is printed, your battery has to be replaced.
You could try, placing the battery on the charger and after a few minuter remove and replace several times. But be aware even if this works, your battery can be over due in a little while. (unless you find something on the contacts, and you can remove this) To clean contacts never use sharp tools. Only a dry cloth.
Jan 07, 2014 | Canon EOS 6D DSLR Camera Body Only
Canon Vixia HF M41 doesn't charge battery - red light flashing rapidly
If you don't use the battery for a long period of time even a new battery may become dead. You can try a new battery. If it still doesn't work then the problem is with the charging IC. u can also try a desktop charger instead of direct charger.
Mar 04, 2013 | Canon VIXIA HF M41 Camcorder
Battery charger flashes yellow light
why my canon battery 1100d charger is blinking
Nov 13, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
How many hours do I need to charge the battery of a new canon camera?
It depends on what camera battery, but usually about 2 - 3 hours. (The LC-E6 battery that comes with the 5D Mark II, charge time for a new battery is 2.5 hours). The canon charger should blink green while charging, then go to a solid green when the battery is charged.
Feb 14, 2011 | Canon Cameras
My digipower travel charger flashs red when the
For mulitply camera battery charger ,there are many special online shop for you to select on the internet.
May 17, 2010 | Digipower Travel Charger for Select...
THe flash of my Optio E10 gone. What should I do?
Make sure the battery is fresh or new.
Make sure to check all your menu settings.
These settings can affect the flash.
You can reset to default...then see what happens.
You can always sell the camera as a parts camera on a site such as Ebay.
Aug 30, 2009 | Pentax Optio E10 Digital Camera
Canon DC 100
check your battery or change it..battery output should have 7.8v.
Oct 31, 2008 | Canon DC100 DVD Camcorder
My iriver shit itself
once your iriver is plugged into the charger and then you hold the power button for a few seconds (if dosn't work, try and try again)
Jan 21, 2008 | iRiver E10 Digital Media Player
Very short battery life.
You could check the manual and/or the Tech support team. But in the main that is what cameras do - eat batteries. Best to get rechargeable sets and a charger I have 3 Li-ON batteries and a charger for my Oly 300 and six sets of 4 AA Ni-Mahs and charger for my E10
Jul 11, 2007 | Konica Minolta DiMAGE E500 Digital Camera
Could I use my Canon bounce flash (550EX) with this Olympus Digital camera?
That's not possible because the hot shoe is not provided for the Canon hot shoe. You can change some wires in the Canon flasunit to let it think is an Olympus model ;)
regards,
Rob
Sep 07, 2005 | Olympus Camedia E-10 Digital Camera
Canon Lc-e10 Battery Charger For Lp-e10 Battery Pack - Eos Rebel T3 Camera Logo
23 people viewed this question
old marine
old marine
