Question about Kenmore Dryers
Dryer Belt Need to find Dryer belt for kenmore heavy duty 70 series. The belt # is 235ET 098 12-0
    Genius:
  • 1,122 Answers
Your model number is inside the dryer door,you can go to your local appliance part store or to sears.com or repair .com or ebay to buy one-mike
Posted on Jun 23, 2009
How to change the belt on a Kenmore dryer
Buy an OEM drive package and follow instructions on package
Sep 17, 2014 | Kenmore Dryers
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
I have a Kenmore Dryer it works but will not tumble i'ts a heavy dudy super capacity 70 series modle 110-64742400 you may need this to dwjr-ele-2406028-fm54
When the drum won't turn and the dryer is otherwise working it's usually due to a broken belt. Open the front of the machine to inspect the belt.
  1. Under the lint door remove 2 screws
  2. Use flathead screwdriver to pry up the top lid
  3. In the middle of the drum should appear a belt, if you see it, pull on it. If it is loose it's fallen off the belt tensioner. If there's no belt of if the belt breaks in your hands, you need a new belt.
A sample of the typical belt routing for your machine is available at the link below:
Kenmore Dryer Belt routing
Sep 08, 2011 | 2007 Toyota Camry
Hi, we have a kenmore heavy duty 70 series electric dryer, it will not start, there is 110v to each leg of the plug, and the door light comes on. What would I check next
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 22, 2010 | Kenmore Dryers
Have a Kenmore 70 Series, Heavy Duty Dryer. Push the on button to start, nothing happens.
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Sep 19, 2010 | Kenmore 700 6972 Dryer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
Kenmore 70 series dryer leaving brown marks
you can get the parts direct from www3.sears.com and to replace it you pop up the top, take 2 screws out holding front panel onto cabinet and take off, take belt loose from idler and motor and slide drum out ,, go back same way / thanks
Jan 13, 2009 | Dryers
Belt replacement on kenmore 70 series heavy duty plus
No belt on this, its a direct drive with a motor coupler..There is a tutorial for this at www.shop.washermd.com Dave
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Need the belt routing for my washing machine
unless you washer was bought prior to 1988 there is no belt ..washer is direct drive with coupling between motor and gearcase
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
253 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
