Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
My refridgerator is built in to the wall so I can't "pull it out" to check anything. It is a GE Monogram..that's all I know. I am renting this place and can't get ahold of the owner. It appears to be fairly new, the owner remodeled the entire kitchen a year ago. Lights are on (nobody home:))..starting to melt, water dripping out of freezer. should I call someone and if so, how much will it cost me for the repair and or appointment?
U should call someone and bill the owner
Posted on Jun 22, 2009
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
The power is off but the wall plug is working, where do I find the fuses that might need replacement
Pull it out from the wall so the back is accessible.
Unplug it. Gotta stay safe.
Lie down and use a flashlight to look at the electrical wires and the component that they connect to. See if there is a red reset button on the compressor. Check the electrical supply cord with a continuity meter to determine if there is a broken wire.
Happy hunting!
Mar 20, 2015 | GE Monogram Refrigerator Built-In...
Ge monogram zfsb23d howls
Usually you will get a sort of whinning/screeching noise from the fans inside the fridge/frezzer when they are not working properly but you can also get that howling noise from the fan which cools the compressor for the fridge/frezzer which is usually found underneath the Unit. All you have to do is find exactly where the noise is coming from and remember unless you have a dog that likes to lock itself in the fridge for a joke then most noises that come from fridge/frezzers are only made from the moving mechanical parts and sometimes leaking refridgerants but not often.
Apr 03, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Hot center wall in refrigerator
This is more likely to a defrost heater sticking on and not turning itself off, could be either a timer, board or defrost temperature sensor issue
Apr 03, 2014 | Refrigerators
How do I change the inverter board on a ge monogram 36" built in, side by side refridgerator ZISB360DX
it's pretty easy,pull off the old board and put the new board on the same way the old board came off,wires go the same place.are you sure that's your problem,GE has had bad mother board problems and everything that runs on that goes through the board,i've changed over 50 mother boards and have never seen a bad inverter board only bad mother boards but i'm not there to see why you say the inverter board is bad.good luck with your machine and changing the inverter board is easy but it's around 300 dollars,unplug the machine and open the cover and check the mother board it's also on the back,back wall with a few screws holding the cover on and check to see if there's any short marks on the board or the metal frame where the board is mounted,i would say that's your problem but like i say you must of checked it with your meter to know it's the inverter board.good luck
Apr 22, 2011 | GE Refrigerators
GE Monogram refrigerator does not cool. The fan on top was loose and not spinning. I fixed that, and it now spins properly, but he freezer and frig will not cool at all.
I need you to pull away from wall and remove cover over compressor and feel compressor for heat. If too hot to hold hand there or if warm or just cool. Tell me what you find. I would like to help you solve this if you like. Sea Breeze
Feb 21, 2010 | GE Monogram ZISS480NRSS 48" Built-In...
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
May 18, 2009 | GE Monogram Side by Side Refrigerator
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
65 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
