Question about Konica Minolta Office Equipment & Supplies
I have a Bizhub 350 and the touch screen has stopped working. Can we find a used replacement or repair?
  • Konica Minolta Master
  • 6,161 Answers
Try online a refurbished or use one
Posted on Dec 30, 2015
Kevin Hayes
  • 167 Answers
SOURCE: problem with bizhub 350
The solution is to place a service call.
It sounds like a component is not functioning properly thus causing a hardware crash
Posted on Jul 07, 2008
ayamaya
  • 143 Answers
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Posted on Aug 26, 2008
jqsababa967
  • 145 Answers
SOURCE: bizhub 350 copier lcd just blue no menu display
IF WHEN power up machine goes to a bright blue screen and then the machine is stuck and it does nothing further.
Description:
Blue screen and the machine is locked up.
Solution:
CAUSE: Failed control panel (UN1).
Posted on Nov 09, 2008
eroesser55
  • 6 Answers
SOURCE: Touch screen on Bizhub c250 doesn't work. The buttons on the right work but the touch screen doesn't?
press the button that says acessability and then press touch panel adjust in the screen.
Posted on Jan 02, 2014
SOURCE: my bizhub 200 touch screen has stopped working how do i calibrate it
Hi David,
here is a website that may help
Acer Support Answers Mail Chat Using Recovery Management outside of...
Posted on Feb 07, 2014
Konica minolta 350 touch screen stopped working
Similar problem with a Canon MG6320 has been solved .There is an updated firmware for this printer that fixest his issue. Download and run it on your computer that is connected via a USB cord directly to the printer.
Jun 16, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Touch screen not working
Touch screen is not repairable only change
change your touch screen then use your machine
Feb 14, 2014 | Minolta bizhub 350 Black and White Copier
How to reset to admin code on bizhub
1. Press the Utility/Counter key.
2. Touch [Check Detail].
3. Press the following keys in this order.
Stop ? 0 ? 0 ? Stop ? 0 ? 1
Then
1. Call the Tech. Rep. Mode to the screen.
2. Touch the [Administrator # Initialize].
3. Select [Yes] and touch [Enter]. defaults the PW 12345678
Feb 08, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
I have a problem for bizhub 350 touch screen malfunction totally not working....please help me to solve this problem...thanks..
you must execute touchpanel adjustment.In the right side on copier in neighborough to USB connector located one plastic door.Pull out the plastic and press a little microswitch.After press the switch wait to appaire a * symbol and press 3.In the blue yield introduction 00000000 and press END.On the touchscreen appaire screen adjustment.
Dec 11, 2013 | Minolta bizhub 350 Black and White Copier
Come resettare touch bizhub 350
What code is being display? What to reset. Touch Screen?
Feb 20, 2013 | Minolta bizhub 350 Black and White Copier
Simulation code for bizhub 350
Press Utility/Counter button, then on left side of display screen touch "details"
Now press Stop, 0, 0, stop, 0, 1
This key sequence will get you in to the service mode. Be careful what you mess with in here.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 27, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c0-510 come on a konica bizhub 350
Fusing error
1. Press the Warm Restart switch, and “●” appears at the center on the left end of the screen.
2. Enter “3” from the 10-Key Pad.
3. Type the 8-digit service code and touch [Enter]. (Default value: 00000000)
NOTE
• When [END] is touched after a wrong service code has been entered, the Basic screen reappears.
• At the fourth access after entries of three wrong access codes, [END] is not available on the screen. It is therefore necessary to turn OFF and ON the Main Power Switch.
• If you forget the service code, it becomes necessary to replace the RAMS Board with a new one. Take necessary steps not to forget the service code.
• The RAMS Board is not available as a replacement part. If it requires replacement, contact Office Printing Support Division by way of CSES.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jul 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
Dec 23, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
20 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
