Question about Westinghouse Washing Machines
Water will only fill up half way when set for a large load and very little water when it's set at medium load.
    Sergeant:
    Champion:
  • 208 Answers
Put less of a load in to compensate the amount of water and save wear and tear on your washer :-)
Posted on Jun 22, 2009
I have a maytag top loading washer. the washer if set to medium load or large or super large load only fills to the half full level,
My maytag has a rubber tube that goes from the bowl up to the level sensor. I would try removing this tube and blowing it out to make sure that it is clear and not perished.
May 26, 2015 | Maytag Washing Machines
After washing 2 loads the machine won't fill to high level it only fills 1/2 way
You have a faulty fill valve. Return/ replace you washer if under warranty. If not then you will have to replace your fill control valve. That valve is where the knob for the fill level is.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Mar 12, 2014 | Danby 1.7 Cu. Ft. 4-Cycle Portable...
FILL CONTROL DOES NOT WORK
Pressure switch needs replacing or adjusting. Don't over adjust. Turning screw in increases water level.
Dec 08, 2013 | Maytag Washing Machines
Washer just keeps filling and never advances on large and medium loads only
Your drain hose is pushed too far down into the drain so when you select the larger load sizes the water is being siphoned out as it goes in due to the pressure differential.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 01, 2012 | Electrolux Washing Machines
I have a ge profile harmony top load washing machine. Is there any way I can get more water to fill with certain loads of laundry?
there should be something on the console that says small medium large,that's the water settings.if you have a few things to wash put it on small,large load fill it up on large that's it.
Apr 09, 2011 | Washing Machines
I put a fairly large load in washer. As the washing started I needed to add an item. I was surprised that the machine had very little water in it. Is there a way to add more water. Also when soaking I had...
The Series 10 and 11 machines have three level fill points the Series 12 and above have two level fill points.
I know Bulky Items wash selection will give you a High water fill which is only 7 inches or so of water in the wash basket. 3.5 inches of water for a medium fill.
You can turn on/open the water inlet valves in Service Mode but I would not recommend that. A manual fill as you did is the only safe way to set the additional water level IMOP.
FAV6800A/FAV9800A Service Manual for reference.
Rich
Jul 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Over filling
pressure switch pipe is either blocked or damaged, the weight of the water pushes air up the pipe to activate the switch to stop the water filling, for some reason its not doing so,
this is a small thin pipe that goes from a point in the machine low down, to a little round flat object (normally) up near the top of the machine inside up near the top
drain the machine and clear out the pipe at the bottom where it joins  the drum or whatever, make sure joints are made good
if i have helped please rate me
Oct 10, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
61 people viewed this question
Top Westinghouse Washing Machines Experts
Mack Baxter
Mike
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
