Question about Pioneer CDJ-800 Turntable
Pioneer cd player not working
The play and cue buttons won't light up. I already changed the laser assembly, but the problem continues. Also it spits out the cd's
  • 68 Answers
Sounds like a laser problem and maybe not put your player back together properly if you have already changed your laser.
if you havent had your player repaired then you can contact me @ www.audiovisualservices.info
Hope this helps you.
Thank you.
Posted on Jan 19, 2010
When i put a cd in the cdj it won't read it and ejects it
This is more than likely a laser issue. Does it spin the disc up? The first thing the CDJ will do when you put a disc in, is look for a reflection of the laser, which tells it that there is a disc inserted. There should be a short pause whilst it does this, before it fails and spits the disc back out again. If this is the case, there is either dirt and grime on the laser lens, or the laser needs to be replaced. Normally I recommend replacing the traverse mechanism, which includes the spindle motor and laser assembly.
If this needs to be replaced, either ask for more help, or contact your local Pioneer Service Agent.
Hope this helps :)
Jaye
Oct 27, 2011 | Pioneer CDJ-1000 CD Player
Where is the button/knob set up to play single song verses continuos songs from a cd on Pioneer cdj mk..
The button you need is the Auto Cue button, which is to the left of the top display. Press and hold to turn auto cue off, which puts the player into continuous mode. This button is also the Time Mode button.
Hope this helps
Jaye
Sep 17, 2011 | Pioneer CDJ-1000 CD Player
My cue button on my cdj 1000 mk2 kept jamming so i got some foam cleaning stuff from a dj shop and sprayed it on the cue button now it started going mad skipping traks, playing in reverse. i think that the...
cue button sticking sounds like the button on the pcu board needs replaced, I would clean all the foam stuff of if possible, as for the screen not working sound like some of your wires have come unconnected easy fixed just plug them back on to the pcu board
Mar 28, 2010 | Pioneer CDJ-1000 CD Player
Queing up on cdj 200
In order to set a cue select th button IN/REALTIME CUE once you do that you an press the CUE button located next to the play buton.
Dec 28, 2008 | Pioneer CDJ-200 CD Player
Tracks start stopping.Cue button playing up.Code E8302 showing
It good be a number of things that can cause this, it could be the quality of your cdr's that your using, it could be your disc copier going faulty, it could be your recording software your using, it could be your disc's are slightly damaged, it could be the speed your your copying your cdr's or it could be your laser pick-up going faulty. If you havent had your player repaired you can send it to us to have a look at it for you.
Regards.
Paul.
http://www.audiovisualservices.info/
Dec 13, 2008 | Pioneer CDJ-1000 CD Player
ON MY PIONEER CDJ-1000MK2 MY CUE BUTTON IS VERY SENSITIVE... I DON'T KNOW HOW TO FIX THIS, I KNOW EBAY SELLS THE PART HOWEVER IM NOT SURE HOW TO REPAIR IT MYSELF AND OPEN UP THE CDJ.
Replace the cue tac switch or worst scenario replace the cue play board.... takes 5 mins to open solder and fit back together or 2 minutes to replace board
Hope this answers your query
MBI
01273 607384
Jul 14, 2008 | Pioneer CDJ-1000MKII CD Player
Cdj-500ll cue button repair
the faulty button will not stop it from playing well... replacing them is not hard so long as you have some experience with a soldering iron.
Clean the laser lens with a cotton bud wet with windex... then use a dry one to be sure no residue is left. If it still mistracks... new optics required!. You willl need a pioneer service agent to do this for you. A little complex for the first timer :)
Jan 08, 2008 | Pioneer CDJ-500II CD Player
CDJ 800MK2
the cue switch has to be cleaned by a technician. if that doesnt work. replace the cue switch.
Jul 15, 2007 | Pioneer CDJ-800MK2 Turntable
Pioneer CDJ-800 Turntable Logo
143 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
