Question about Yard Machines Garden
Kx 80 thick oil out the exhaust and white/blue smoke?
Stalls a lot if you come to a stop or slow down.smoke and thick oil out of exhaust,
  • 2,042 Answers
Could be bad piston rings but first check your oil in the engine and if its too full this could cause burning oil. Check your air filter and if its clogged replace it as this will do it also.
Posted on Jul 19, 2015
SOURCE: 14.5hp B&S ohv looses powes & blows white smoke on riding mower
This engine has a badly designed combustion head that causes premature failure of the head gasket. The removal of the overhead cam and head is relatively easy with the engine mounted on the mower. Just remove the hood before you begin. I had the same problem, same symptoms (white oil smoke, mostly when turning or on an inclide-=left side downhill) after the second season of mowing. Made me mad when I got it apart and saw the incredibly stupid head design. Replaced the head gasket and am into my second season with the new head gasket with no more problems but I expect it to blow again at some point. Poor engine design. Easily fixed.
Posted on May 24, 2009
  • 468 Answers
SOURCE: 05 42''MTD 18.5 HP B&S Intec OHV White/Blue Smoke/oil in exhaust
From the sounds of it, you've at least lost the rings in your engine. I'm not sure of the circumstances, but it almost sounds as if it had too much oil in it. These small engines lubricate themselves by throwing oil all over the inside of the engine, and if too much oil is in there, it won't throw it. They will also burn oil off if it gets into the cylinder from the level being too high. This would give you your bouts of blue smoke. The grinding noise that you describe may or may not be an issue, but here's something you need to try. First, make sure that the oil level is exactly as it's supposed to be. Then, remove the spark plug and see if you can get it to turn over. If the cylinder's full of oil, it won't compress, and it won't let it turn over with the spark plug in. Next, get a can of starting fluid, and spray it in the spark plug hole. Crank the engine over with no spark plug in it. Repeat the starting fluid, cranking cycle until you don't see any more oil coming out. Leave the spark plug out, and let it sit for a couple of days to evaporate. Clean out the plug or replace the plug in the meantime, and then reinstall and attempt to start. It'll probably smoke like crazy for the first 15 minutes, and then be fine after that. This is the number 3 problem I've found when repairing small engines; with #1 being flooded, and #2 being having water in the fuel. Leave a comment if you find that it won't move even if you remove the spark plug, and I can discuss more with you then about your options.
Posted on Mar 25, 2010
  • 111 Answers
SOURCE: I changed the oil and
Depending on if you laid the engine over on its' side, there could have been oil in the muffler. It may take some time to "burn" this off. It will also come from the muffler. Given enough time the oil will get hot and smoke off of the muffler. Then it will no longer smoke.
I hope this answers your question.
Posted on Apr 05, 2011
philwalker78
  • 608 Answers
SOURCE: lawn Boy pushmower blew out
Hi, change the oil and your problem will be solved. Basically it was over full because fuel has by-passed the carby needle and leaked into the sump while its been sitting idle. Regards Phil.
Posted on Aug 14, 2011
  • 6468 Answers
SOURCE: oil and white smoke out through exhaust?
smell the oil if it smells like gas change the needle and seat inn the carb and change the oil the valve in the carb doesn't seat and the gas drains into the oil
Posted on May 25, 2012
Have a rotten egg smell with no catylatic converter lots of smoke out the exhaust
smoke usually means the piston rings are bad...try an additive to slow down the smoke if possible...
Jun 02, 2015 | Cars & Trucks
Thick white smoke out of tailpipe. No power loss. smells like oil burning
start with seal valve but try do this Replace your engine oil to 20/50 synthetic Valvoline .and add oil stop smoke . i hop for you the best .
Nov 21, 2011 | Cars & Trucks
My bike wont stop smoking and wont rev properly i carnt put the power down on the bike it feels like it is missing on full revs my bike is a kx 85 motocross 2007 model
If it's blue smoke, maybe an oil ring is broken. White smoke and water in the combustion chamber, black smoke carburation problems.
Feb 07, 2011 | kawasaki KLX 110 Motorcycles
I have a 2005 Nissan Altima 2.5. Thick white smoke is coming out the exhaust after a cold start. It is using a little oil. Valve seals, rings , or what?
usually white smoke means prestone leak head gasket if black rich mixture if blue oil consumption do a compression test to find the problem or check levels to see if they are low
Jan 05, 2011 | Nissan Altima Cars & Trucks
97 f250 5.8L starts to run rough and puffs out thick black smoke. It comes and goes. Any ideas?
Exhaust problems. Black smoke=exhaust, blue smoke=oil, white smoke=water.
Aug 05, 2010 | 1997 Ford F250 SuperCab
Its blowing white smoke from exhaust
Sounds like you blew a headgasket. When this happens water can mix with oil and it makes the oil look white and foamy when you look into the oil fill cap. Another version is oil mixes into the water and gets into your radiator, this makes the same thick white mess and both versions would have to be thoroughly flushed depending on which got into the other. You could of also just blew the gasket between a water or oil jacket and a piston cylinder. This will cause the fluids to pump into your cylinder, heated and then be forced out the exhaust pipe. If water is mixed with this it will billow out white smoke(steam) in huge amounts. I would check your water levels and oil levels very quickly to make sure it does not empty those systems out and burn your motor up.
The last item is the worst outcome. If a crack somehow was created in the engine block or the head of the motor, the same thing could happen as it exited out the exhaust pipe. Though this is the worst case of really thick white smoke out exhaust.
Resolve: time for a mechanic to diagnose this one before it stops running completely.
May 12, 2010 | 2000 Dodge Intrepid
Thick oil, blue smoke from exhaust
sound like you have blown head gaskets and water getting in the oil
Mar 08, 2010 | 1998 Saab 900
Pop noise with thick white smoke from front end,
sounds like you might have a cracked cylinder and oil puddled up inside over night and when you started it..it blew out through the exhaust. White smoke means oil...black smoke means gas ,and blue smoke means both..if you cracked a water jacket your oil will look like a bubbly milk shake.....take a look at your oil.
Sep 08, 2009 | 2008 Yamaha YZF-R6
Thick white smoke coming from exhaust
you have a blown head gasket you need to get it to a shop as soon as you can
Feb 04, 2009 | 2007 Jeep Grand Cherokee Overland
Garden Logo
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
