Question about Zebra GX420t Thermal Printer
Why is my gx420t printing one copy then sends two blanks then prints again
Lexmark s605 won't make a copy
Check settings from computer, try to send command from computer to scan and copy. May have to plug usb cable in to access all settings unless it's wireless only.
Apr 01, 2014 | Lexmark Office Equipment & Supplies
Zebra printing continuously problem
disconnect printer from computer and power on again. at driver chech if still jobs there and clear buffer. at printer, if still printing whithout connested its becase it still have information to print. just reset printer to factory default or let job to finish.
Mar 18, 2014 | Zebra GX420t Thermal Printer
I send a print but pages aqre blank
Does this happen when copying? Can you print internal copier form meter count etc.?
Mar 14, 2014 | Konica Minolta bizhub C250 All-In-One...
Gx420t printing blank configuration pages
Could be faulty printhead. OR ribbon is put in the other way around. hard to say. It would be better off call the service technician.
Sep 27, 2013 | Zebra GX420t Thermal Printer
Printer printing in batches, delay when printing
Desktop printer has limited memory. It's all depending on how many information you put in the label. Your communication cable used? USB or serial? what type of fonts you use
Sep 03, 2013 | Zebra GX420t Thermal Printer
On canon iR 1020, i cannot print and make a copy
Do you mean that you have blank copies/prints, or that there is some message on display, or just blinkig red led...?
If yyou have blank copies the problem is in laser shutter.
If you have error message send detailed description.
May 21, 2010 | Canon NP 6035 Copier
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
ADF Pulls paper but prints a blank page
The wire ends have different sizes to avoid to connecting it to the wrong port. It will only fit to the right one.
If the copy prints a blank page, try copying again with the document facing up on the ADF.
Hope this helps!
Mar 03, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Zebra GX420t Thermal Printer Logo
52 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
