Question about Zebra Z4M Printer
What is the difference between a Zebra S4M and Zm400
ashish13
  • 75 Answers
SOURCE: Some noise comes when printing
Here is the link for the Service Manual required which i uploaded for you... hope this resolves your issue...
http://www.adrive.com/home/downloadfile/136030403
Posted on Feb 12, 2009
  • 90 Answers
SOURCE: Jammed S4M Printer
Do what the other guys did and cut the labels and pull it with a set of plyers. Does not seem to be a better way
Posted on May 28, 2009
  • 3 Answers
SOURCE: How do I identify my SM4??
The configuration code you posted uses ZPL II or XML
Have a good one!
Brian Wallace
Peak Technologies
877-863-2522 x 6807
Posted on Jul 10, 2009
  • 32 Answers
SOURCE: Zebra S4M label printer
Check the drive belt. It might be missing a tooth if the printer is older. I can assist if you want to check this.
Posted on Oct 27, 2009
ozztech
  • 285 Answers
SOURCE: como cambiar ip de zebra zm400 desde el panel
you need to connect with some network to the ip adress coming on the setings, if you dont connect with network, that function not apper.
If connect, you be aple to change to IP estactic and the Gateway and the subnet mask.
Dont forget to save.
Posted on Nov 13, 2010
How to fix dissapear printing label for Zebra ZM400
Hi, please be more especific regarding issue, can be software issue or hardware issue.
Jun 20, 2014 | Zebra ZM400 Thermal Label Printer -...
Zebra zm400 does not want to print from file
Hy, what file? thanks. try driver from www.seagulscientific.com.
Jun 03, 2014 | Zebra ZM400 Thermal Label Printer -...
Zebra printer drops network
i hadthe same issue with all my zm400's, but not my zm4 plus's. zebra gives you the run around when contact their technical support.
I tried every setting there was, ended up get rid of the zm400's, they are a piece of C#@P
Feb 03, 2012 | Zebra ZM400 Thermal Label Printer -...
For ZM400 and S4M, Has anyone had any luck with printing a white ribbon and a black or dark label without covering up the ribbon sensor with electrical tape? Isn't there a setting that can be...
You can try this: on the S4M, you can press the Menu key to go into setup mode. Under password level 3 parameters,there is a setting for ribbon which by default is set to Yes thermal trans. If you set it to No for direct thermal mode, this will in effect turn off the ribbon sensor. The printer won't stop now if it runs out of ribbon but usually you are there when printing to see that the ribbon is running out.
On other Zebras, you can turn down the sensitivity of the RIBBON LED sensor but the S4M doesn't have that setting.
See if that helps.
Jun 20, 2011 | Zebra 203DPI Printer
Ribbon is out on zebra s4m
Should be able to order this:
http://www.barcodesinc.com/zebra/s4m-ribbons.htm
May 03, 2011 | Zebra S4M Thermal Label Printer
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
How do i change the media power calibration on a Zebra S4M printer
Go to www.zebra.com and download the S4M pdf user manual. It guides you how to change configuration.
Oct 27, 2010 | Zebra S4M Thermal Label Printer
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
How to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Jul 10, 2009 | Zebra ZM400 Direct Thermal-Thermal...
Zebra Z4M Printer Logo
83 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
