Question about Hasselblad 503CW Medium Format Camera
I bought a used V96 Ixpress digital back for my Hass. 503CW
But I did not get the shorter cable that connects the digital camera back to the battery pack. I have the long cable but it is too long to take in the field. Where might I locate a short cable to purchase?
Thanks.
2 Suggested Answers
SOURCE: Whats the diff between the 503cw and the 503cxi?
The only real difference between the two is that the 503cxi have a too short, vignetting, mirror. The 503cw have a long, non-vignetting mirror. The vignetting is only noticeable in the viewfinder, and when using lenses 150mm or longer.
Both bodies will accept winder CW, and both have TTL flash metering.
/Chris
Posted on Jan 19, 2009
Just purchased lithium batteries and indicator showing low battery
Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Jan 09, 2014 | Samsung S860 Digital Cameras. 8-megapixel...
Just bought the panasonic HM TA1 an its charged an everything an when i connect the camera to the computer it turns on for a second an says connecting then goes off . it wont turn on at all when i havent...
Sounds like it needs a battery.
After a few years those batteries will charge up to the correct voltage, but the length of time that charge lasts gets shorter and shorter, You probably have a drill, a razor, a laptop computer, or a flashlight that do not hold a charge as long as they used to, I know that you have a camera that doesn't hold a charge .
Sounds like a battery problem,
Mar 03, 2018 | Panasonic HMTA1 Camcorder
My batteries are lasting shorter and shorter times. I had to change batteries after only 40 pics. Is it a camera problem or cheap batteries? I normally use the CRV3 batteries, but have been using AA's. Is...
Digital cameras are famously demanding on batteries. You must use good alkaline batteries or better, a set of high capacity NiMH rechargeables. Zinc or "long life" batteries just aren't up to the task, and they can leak and cause corrosion.
NiMH batteries with a capacity of 2700mAH are available, and these will last longer, per charge, than name brand alkalines, as well as being rechargeable. You can buy these with a charger fairly cheaply now (though they obviously cost more than disposables). You will probably want two sets, one to be on charge while you use the other.
Jan 02, 2011 | Kodak EasyShare Z740 Digital Camera
Camera says replace batteries even when fresh ones are installed
Sir/Maam,
Have you tried using new batteries? How long have you been using the old batteries? As far as i know, the longer you use a rechargeable batteries, the shorter its life(compared to the first time you used it).
Try using new batteries, if the problem is still there, the camera my have the problem. But if the camera works fine, then your old battery is defective.
Keep me update, hope i helped you. Thanks.
Feb 27, 2010 | Canon PowerShot S3 IS Digital Camera
Adapt a Hassie 500el/m to a Imacon ixpress back V 4.7
The Hasselblad ELM does not need adapting to use the Imacon or hasselblad digital back  the following backs fit on the ELM and can be triggered with a cable that should be supplied with the back.
Hasselblad V96c 16mp square format back  Hasselblad CFV 16mp square format back with CF slot Hasselblad CFVII 16mp square format back with CF slot + larger screen
the following backs will work but need to have a V adapter plate fitted to the back
96c 16mp square format back  132c 22mp 645 format back  528c 22mp 645 format back with Multishot option CF-22 22mp 645 format back with CF slot CF-22 MS 22mp 645 format back with CF slot & Multishot option CF-39 39mp 645 format back with CF slot CF-39 MS 39mp 645 format back with CF slot & Multishot option
When fitting and digital back to an older camera the best advice is to get the camera body serviced to ensure that the back mount is correct as the digital backs require a better fit than the film backs did. If the mount is off it will cause back or front focus.
Mar 16, 2009 | Hasselblad 503CW Medium Format Camera
/Chris
Jan 10, 2009 | Hasselblad 503CXI Medium Format Camera
503CW with leaf back
Can you shoot rear curtain flash modes?
If not, try this:
Advance the camera.
Open up the shutter(set mirror lock-up). You'll have to remove the Winder CW to do this.
Push black Tap up to open up the shutter. Don't worry, lens is still closed.
You'll not see anything from the viewfinder, just black.
Trip the shutter button.
Now, check the images.
What do you get?
Try shooting under one second in low light.
Battery is new and not over 5 years old?
71% related to digital back
24% related to battery
4% related to electronic/mech problems & human errors
1% related to camera's back to digital back
atdlee@netzero.com
Feb 25, 2008 | Hasselblad 503CW Medium Format Camera
Unsharpness
if you can acquire sharp image with your 80mm, but not the 50mm and 120mmmm, there is no problem with your camera body, i.e. lens-flange to film plane. but how come you can not manage to get a sharp spot anywhere from the full turn of focusing rings with your 50mm and 120mm, unless the lens units inside these 2 lenses shifted. i doubt this happened to both lenses simultaneously?
if you are sure that your lenses have problem, send them for focusing test, since they are good and expensive lenses.
pc-cook
Sep 14, 2006 | Hasselblad 503CW Medium Format Camera
Going through batteries abnormally quickly
Hi. I bought a used A70 that had that problem. I disassembled the outer body panels and found that a base panel assembly screw was too long, and was touching the LCD's ground cable, at the cable's tip. I changed the screw for a shorter one and it was settled. It never happened again.
May 31, 2006 | Canon PowerShot S1 IS Digital Camera
Hasselblad 503CW Medium Format Camera Logo
219 people viewed this question
Top Hasselblad Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Hasselblad Photography Expert? Answer questions, earn points and help others
