Question about Maytag MFC2061HES Stainless Steel French Door Refrigerator
How can i fix he water stopped working on my model mdf2561kes
My water dispenser quit working any ideas on how to fix or reset it
Mine just stopped also, apparently the water line on certain models is prone to freezing inside the door, (your model is included in the list). After time (in my case 8 years) water migrates into the foam insulation. You can thaw it out with a hair dyer but it will probably freeze again. Here's a link to a part you can get to fix it, haven't received mine yet so I don't know if it works (others say it does). Just call GE and demand that they sell it to you for $20. They will if you're persistatnt Redirect Notice
Feb 22, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
The washer work but stop along the way,ie unable to complete the circle
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge washer won't stop draining water even before
Try these
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Pls rate my suggestion...
Jul 23, 2009 | GE Washing Machines
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
My washer wont stop filling up.cold and warm work but it doest know when to stop filling up hot doesn't work at all.please help my water bill was really high this month it a kenmore 80 series...
There is a defect or , malfunction within the Water fill level pressure switch. this switch will cost about 35 dollars and, it should be replaced asap.it has failed.
Replacing the
Water fill level pressure switch, will fix your issue.
Jun 16, 2009 | GE WBSR3140DW Top Load Washer
Ice maker stopped working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MFC2061HES Stainless Steel French Door Refrigerator Logo
15 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
