Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
C970 646123 oven failed - Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven not heating up
What is the thermostat neon doing? Is it staying on, or not on at all? If it stays on then the element has failed. If it is not on at all, then it could be that the element has failed and taken out the thermostat as well. If the neon is not on at all, it could also mean that the thermostat has failed by itself. If it is either of the two or both, the oven will have to come out of the kitchen carcas to replace the components. As a general rule, if the element fails you should replace the thermostat as well as the element failing can cause abnormal stress of the thermostat contacts, which then could fail at a later date. The handbook has the wiring diagrams in, so if you can find a tame electrician, he should be able to test and see what has failed before you buy anything. Try espares for parts.
Jan 01, 2012 | Stoves 720EF Electric Double Oven
When I try and Bake or Broil the oven beeps and gives a fault code of F3EO
HI. Generally, this will be the cause of a failed oven temp sensor. If your unit's orientation is doubled, the top oven sensor will be the culprit. Some model will incorporate a sensor fuse at the wiring harness. Check the fuse, if equipped, for continuity. If the fuse is bad, replace it. If the fuse is ok, replace the oven temp sensor.
F3E0 - Failed oven temp sensor(top sensor if double oven)
Mar 01, 2010 | Whirlpool Ovens
F4 error message
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
It will look like a 4 inch slim probe.
F4 failed temp sensor.
Dec 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
FAN ASSISTED PART OF OVEN DOES NOT WORK - ALL OTHER PARTS OF OVEN WORK
3ce67db2-692b-4b64-9a3b-5ffc185dfc29.pngIf its convection , take the back panel off inside the oven an change the element . Ta daaaaaaaa !
Dec 26, 2009 | Bosch Ovens
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Kebs208d THE DOOR WILL NOT UNLOCK
HI, this is a major control fault. you will need to replace the Oven control asap if possible. It has failed.
Possible causes--
*Power surge
*Failed logic(IC)
*Oven Temp Sensor failuer that has resulted in extreme temps that has overheated the board.
Jun 07, 2009 | KitchenAid KEBC207 Electric Double Oven
Oven turning off
F3 - E4 Oven temperature sensor (RTD) opened (lower oven, if double oven). You will have to replace this failed sensor to restore normal operations. If your oven is a double version, it will be located in the lower part. If its a single range, it will be located in the oven compartment. The Oven Temperature Sensor has failed.
Please rate and god bless:)
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Kenmore oven model # 79071053400
Check for a loose bulb or faulty door switch. Sometimes a bulb can fail and the filament can reconnect to work at a higher wattage before failing completely.
Jun 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
16 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
