Question about Oster 6330 4-Slice Toaster
Cannot remove cap on thumb lever - Oster 6330 4-Slice Toaster
I am trying to remove a deadbolt with no visible screws. Every site I have been to says to locate the small pin-hole on the shaft. Use a paperclip or an awl with a fine point to press the pin-hole to
What kind of a deadbolt do you have. You will need product specific instructions. Is it a single or a double deadbolt. If it is a double there is likely a cap that covers the screws and it can usually be popped off with a knife blade end or such.
Oct 04, 2014 | Cars & Trucks
This information sounds more like it applies to a handset rather than to a deadbolt. What type and model is it. If as in handsets there is in fact a pin hole release mechanism you will have to have the so called thumb-turn lever rotated to the correct position to insert the pin to contact the internal lock releasing mechanism and push it in to release the thumb-turn knob.
How can I remove the top cap of the winding lever for Pentax K2? This is for me to remove the top cover as the lever is a bit sticky and I would like to lubricate it
K1000: Remove counter cover (3 setscrews around perimeter), remove counter disk (screw is right threaded - turn right to remove!!!!!), washer if not glued to bottom of disk, round nut with slots (also right threaded), lift off counter base, three advance lever spring screws, turn spring until loose, remove advance lever, remove washer underneath
K2: using a rubber stopper, and downward pressure on the cap/ cover screw, turn to right (this cap screw is right threaded!!!)If you try and turn it like you would a normal screw you will break it off. If the camera has corrosion under the cap screw it may stick - try heating with a soldering iron (careful the screw cap will be very hot). In extreme cases I have drilled two holes (one on either side) and used a pair of round nose fine tip pliers to turn it.
Unsure of which model you have as both are mentioned in post
Oct 25, 2013 | Pentax K1000 35mm SLR Camera
Trying to remove the stick shift from a 1992 toyota pickup to replace the clutch
REMOVE TRANSMISSION SHIFT LEVER FROM INSIDE OF VEHICLE
    • Remove the four screws and remove the shift lever boot retainer.
    • Pull up the shift lever boot.
    • Cover the shift lever cap with cloth.
    • Then, pressing down on the shift lever cap, rotate it counterclockwise to remove.
    • Remove the shift lever.
62409690
Jan 22, 2011 | 1992 Toyota Pickup
How do you remove a cap from a delta 522 faucet without breaking the faucet? It currently leaks (water wells up from around the ball) when you bring the handle down slowly. Do you have to remove the...
Sorry to read about your problem, I hope this helps you out.
their is a round top part of the handle, take a knife and pry off the cap, then you will need a Phillips
screw driver
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Delta 522-MPU Classic Single Handle...
The lever to push down the toast will not lock in to start the toastng cycle
Inside the toaster (behind the toast, bagel, etc. Buttons) there is a magnet, this needs to be clean for the taster to lock. First, unplug the unit. Now remove the cap on the thumb lever and the four screws at the bottom, separate the toaster. Now you will see the magnet, remove any debris with a dry towel or with your finger tip. After properly re-assembled this should work.
Dec 20, 2009 | Oster 6330 4-Slice Toaster
My Stihl 210 saw will not shut off . After I flip the lever to the up position it just keeps idling. Have to switch it up and down numerous times for it to finally stop.
Pull the trigger, set the thumb-lever to full choke, and remove the air filter cover. Observe the flat brass spring behind that cover (on the left side of the unit). It should be ABOVE the shaft that rotates when the thumb-lever is moved up or down. Also notice the black wire with a round brass terminal on the end. That is the "stop-circuit" wire and should be inserted into the notch atop the rotating shaft, directly UNDER the flat brass spring.
If assembled correctly, the terminal end of the black wire will rotate when the thumb lever is moved upward and it will slide UNDER the flat brass spring to kill the engine by grounding it out. If the flat brass spring is located UNDER the shaft, it will not contact the wire's terminal. To avoid this in the future, always pull the throttle trigger BEFORE moving the thumb lever to choke position. If the thumb lever is pressed downward without pulling the throttle trigger first this issue will happen again.
Feel free to comment if this does not resolve your issue.
Hope this helps,
Dolf-
Oct 18, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Can't find ink storage
look at this
Details Issue: How do I replace or insert an ink tank?
Solution: Install the Print Head and Ink Tanks - MP620 / MP620B
  1. Open the Paper Output Tray (A), then lift the Scanning Unit (Cover) (B) until it locks into place.
    The Scanning Unit (Cover) (B) is fixed automatically.
    The Print Head Holder (C) comes out. (This is where you install the Print Head.)
    Note : Close the Document Cover (D) and lift it with the Scanning Unit (Cover).
  2. Raise the Print Head Lock Lever (E).
    i_expl.gifCaution : Firmly raise the Print Head Lock Lever until it stops. (The Print Head Lock Lever may feel heavy.)
    i_note_e.gif Note : If the Print Head Holder does not move, make sure that the machine is turned on.
  3. Remove the Print Head from the silver package.
    i_expl.gifCaution : There may be some transparent or light blue ink on the inside of the bag the Print Head comes in, or the inside of the protective cap - this has no effect on print quality. Be careful not to get ink on yourself when handling these items. Be careful not to stain your hands.
  4. Remove and discard the orange protective cap.
  5. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
    i_expl.gifCaution : Do not knock the Print Head against the sides of the Holder.
    Be sure to install it in a well-lit environment.
    Pinch the Print Head Lock Lever firmly and lower it gently.
    Once you have installed the Print Head, do not remove it unnecessarily.
Install the Ink Tanks
  1. Pull the orange tape (1) in the direction of the arrow to peel off the protective film and remove the film (2) completely.
  2. While pressing down with your left thumb, twist off the orange protective cap (A) located on the bottom of the ink tank.
    i_expl.gifCaution : Do not hold the sides of the ink tank; ink may splash.
  3. Install the Ink Tank
    Press the PUSH mark on the ink tank until it clicks into place.
    Make sure the Ink lamp lights red.
    i_expl.gifCaution :Be sure to install it in a well-lit environment
    i_important.gif Important : Match the labels when installing.
  4. Install all the other ink tanks in the same way.
    Install all the ink tanks.
    i_expl.gifCaution :Once you have installed the ink tanks, do not remove them unnecessarily.
    i_important_e.gif Important : Make sure all the Ink lamp lights red.
  5. Close the Scanning Unit (Cover) (B).
Mark
Apr 16, 2009 | Canon PIXMA MP620 All-In-One InkJet...
How do I use a Blackburn Mountain air pump?
Dear Doug, to lock a hand pump onto the valve stem: 1.depending on valve type-loosen the valve lock for presta, twist off valve cap for schrader. 2.unlock the pumping handle from the pump so that you can actually "pump" the pump... 3. put the pump head on the valve of the tire, then pull up on the thumb tightening lever. This should squeeze toghether the internal rubber gasket of the pump, and lock on to your valve. 4. Begin pumping. 5. when desired pressure has been reached, push down on the thumb lever to unlock the pump. Remove it. Good Luck Fellow bicyclist!
Jan 18, 2009 | Blackburn Mountain Air Mountain Bike Pump...
Shifter indicator light
is this the shift position indicator like drive, park reverse, neutral?
Transmission Selector Lever Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the heat shield.
  1. Disconnect the selector lever assembly.
    1. Disconnect the selector cable adjusting cap.
    1. Disconnect the selector cable.
    1. Remove the nuts.
  1. Lower the vehicle.
  1. Remove the selector lever assembly.
    1. Remove the cover.
    1. Lift out the selector lever assembly.
    1. Disconnect the selector lever electrical connector.
Oct 20, 2008 | 1999 Mercury Cougar
Oster 6330 4-Slice Toaster Logo
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
