Question about Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower
Put it in gear and it doesnt move - Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower
2000 Nissan Altima What would make it not move forward or reverse the car starts the gear Shift moves but the car doesnt move. When put in a gear the engine idle changes as if
Transmission is either low in fluid or has gone out. Crank it up and let it warm up to operating temp then pull emergency brake and put car in neutral. Check fluid to make sure it's full and not a dark color. If it's real dark then the trans is burnt up.
Feb 20, 2015 | Nissan Cars & Trucks
Why doesnt my nissan altima shift
Im assuming you mean that the vehicle wont move when put it in gear and its an automatic! Check the transmission fluid level if it is ok check if vehicle will move in any other gear reverse 1 or L etc. If not it maybe a torque converter issue and maybe best for a transmission shop to sort
Apr 14, 2014 | 2005 Nissan Altima
When i put my car in gear it doesnt move. i checked the fluid and it is full. could this be a problem with the computer on the tranny. The first time this happen i was backing out of my driveway and i...
if ur digital screen where it shows what gear ur in has an E rather then R or D when in gear then it is a tranny problem, error code could be minor or not either way a bit costly
Feb 17, 2011 | 2002 Lincoln LS
Not taking gear
if its a auto then start engine and put handbrake on ,select reverse gear and check the fluid level .if its a manual then put in first gear depress the clutch and start engine if car moves its the clutch operating mechanism ,if it still doesnt move then its a new clutch
Nov 30, 2010 | 2006 Hyundai Sonata
1997 vw jetta tdi put in gear but does not move as if clutch doesnt release i can put it in gear with no problem but when i let the clutch out it doesnt move
Sounds like the clutch has perished! possibly the thrust bearing, simply replace the clutch!
one thought... take a look at the clutch cable to see if this has not broken or come off it's housing on the gearbox!
Hope this helps
Oct 29, 2009 | 1997 Volkswagen Jetta
Gear indicator doesnt move when i put the truck in gear
there is a small cable on the indicator but it is not replaceable the indicator has to be replaced and comes withe the new cable
Jul 11, 2009 | 2003 Ford F250 Super Duty Crew Cab
Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower Logo
63 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
