Question about Epson GT 9500 Flatbed Scanner
Why can't scan document
Hope u can help me
  • Harrie May 08, 2014
    Hi mohd hapiz b mohd amin, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? This looks like, writing to a doctor and only say I feel sick.
    Everyone can guess you address a doctor because you are sick, but with writing only these words no doctor can help you. Just telling us, you can't scan is really not enough.
    Please tell us what computer you use. What software you already installed and when. What happened while installing the scanner software. What the software and / or computer says (error messages and so on).
I scanned photos but cannot find them anywhere on computer.
scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it my documents (my pictures) most common
hope this helps
May 19, 2011 | Computers & Internet
When you scan a document where on the computer do you find the scanned document
The scan destination on your computer may vary depending on the path that you set. This article in the Lexmark website on How to Scan Using the Lexmark X5400 Series All-In-One might help you understand the process. Notice Step 6 on Scanning a Document, that's the part where you set your preferred scan destination - either in your Documents folder, on the Desktop or your personal folder.
I hope this information has been helpful. Thanks.
Feb 17, 2011 | Lexmark X5470 All-In-One InkJet Printer
How can I email a scanned document or picture to myself?
just attach the scanned documents and sent it to your email id
Nov 14, 2010 | HP OfficeJet J4580 All-In-One Laser...
I cannot scan document and attach it to the email. Please help. I have wireless HP C7280 printer and scanner and Mac PC. thanks!
depending on your scanner lay the document to be scanned face down scan the document at the end it will ask you what format to be saved in select color i found if you select grey scale it comes out blury then save it in my documents/my pictures create an email click insert file attachment select browse to this document then attach it done
outlook express
hope this helps
Oct 23, 2010 | HP Photosmart C7280 Printer
How do i scan a document?
Visit to the given link and download the manual. The detail procedure is given in the manual... http://www.retrevo.com/support/HP-J4580-Multifunction-Printers-manual/id/20067ag014/t/2/
Hope this has helped you.. Please rate the answer.. Thanks...
Jun 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
My HP J5780 will not scan.
you document was place in a different direction, try to place the document in the right place and scan again.
hope this helps
Aug 06, 2009 | HP Officejet J5780 All-In-One InkJet...
HP 5590 - cannot scan and save doc directly to jpeg format
I need the scanned documents be saved as pdf in HP scanjet 5590
Apr 27, 2009 | HP 5590 ScanJet Flatbed Scanner
Scan a Document and Need to edit in Word 2007
Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Scanning
You'll need a scanner with an automatic document feeder (ADF).
Here's a Microsoft article on scanning documents, including scanning multiple documents info one file.
[Scan a document - Microsoft.com]
I hope this helps.
Greetings,
DarkNeogen.
Jan 05, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Epson GT 9500 Flatbed Scanner Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
